220v Circuit - One Outlet Only? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 05:53 AM   #1
220v circuit - one outlet only?
Wiring my garage shop. Had an electrician install a subpanel in garage. Now I'm adding circuits for 220v tools.
My understanding of code is that you must have a separate breaker for each 220v receptacle, right? If so, I'm going to have almost all of the subpanel occupied already. If I could put two tools on one circuit that would help. Can I?
hippodrome is offline   Reply With Quote
Old 10-18-2011, 06:10 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Where in the coded did you see this?
If you can find it and post it I'll buy you a coffee.
Old 10-18-2011, 06:15 AM   #3
You must have a breaker for each 120V or 240V circuit, not for each outlet. You can put as many tools as you want on one circuit(mutliple outlets), but you probably can't run them all at the same time.
Old 10-18-2011, 04:52 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What will your be powering with 220. If you are using different amperage equipment then they should be separate. You can't have 15, 20, 30 amp outlets all on the same circuit. I have seen people do some weird stuff taking a 30 amp 220 circuit and then also having 20 amp and some 15 amp 110 stuff wired to it. If this is something you are talking about then don't do it.
rrolleston is offline   Reply With Quote
Old 10-18-2011, 05:05 PM   #5
Rewards Points: 502
I have no problem plugging my 1 amp battery charger into standard my 20 amp circuit.
Why can't I change the plug on my 20 amp planer to plug into my 50 amp welder outlet?
If you are talking a 4 wire circuit, they are intended to supply both 110v and 220v power. There is no reason I couldn't stick a 14-50p onto my clock radio and plug it into my range outlet, apart from it would look silly
forresth is offline   Reply With Quote
Old 10-18-2011, 05:12 PM   #6
rrolleston's Avatar
If you ever get a short in your 20 amp planer while plugged into a 50 amp outlet burnt wires don't smell too good. Not a really good idea especially with high amp circuits.
Old 10-18-2011, 05:48 PM   #7
The breaker does NOT protect the equipment, it protects the circuit conductors.
My Miller welder has a #10 cord and plugs into a 50A receptacle. Are you suggesting this is not safe?
Old 10-18-2011, 06:09 PM   #8
rrolleston's Avatar
I prefer to have the over current protection of 220v equipment match the equipment that is plugged in. I thought this was code.
Old 10-18-2011, 06:13 PM   #9
You need to match the receptacle, not the load.
clashley is offline   Reply With Quote
Old 10-18-2011, 06:24 PM   #10
No, it is not code at all.
How is a 240v circuit ANY different from a 120v circuit???
What about a 1/4A bath fan, or clock radio, or TV, plugged into a 20A branch circuit? How is that any different than the OP's scenario?
Old 10-18-2011, 07:18 PM   #11
I=E/R
a7ecorsair's Avatar
In addition, what about a NEMA 5-20T or 6-20T these accept either a 15 or 20 amp plug.
a7ecorsair is offline   Reply With Quote
Old 10-18-2011, 07:36 PM   #12
rdhd
Call the Licenced Electrical Contractor back and explain exactly what you need.
If you do the work and something happens or fails I am certain that your Insurance will not cover it.
This is why professional contractors do their apprenticeships. It is not for learning how to marette wires together or how to staple wire to wood , they are learning code for your specific region.
It may cost you a few hundred dollars but it may save you tens of thousands.
rdhd is offline   Reply With Quote
Old 10-18-2011, 07:44 PM   #13
This is not at all true. At least in the US.
Old 10-18-2011, 08:45 PM   #14
rdhd
I am in Canada, if the insurance company can prove that the homeowner did the work themselves (or an unlicensed friend) they will not honour the policy. There may be exceptions in certain circumstance.
The best solution is to follow the local code, licensed or not.
Old 10-18-2011, 08:47 PM   #15
I=E/R
a7ecorsair's Avatar
I am in Canada, if the insurance company can prove that the homeowner did the work themselves they will not honour the policy. There may be exceptions in certain circumstance.
Update your profile so we know your location. It makes a big difference on this forum...
The Following User Says Thank You to a7ecorsair For This Useful Post:
rdhd (10-18-2011)
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Moving a 220v outlet to a different room? seanfool Electrical 4 11-11-2009 05:33 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Dead outlet and switches on otherwise live circuit viking1974 Electrical 4 08-23-2007 05:30 PM
