Ok, I have a problem I just moved into a new house and when I went to connect my Air Compressor, I found out there wasn't enough room on the panel for another breaker (dual 30 amp). So without replacing the entire service panel what other otions do I have?
For a diyer, I'd recommend a quad breaker just for the fact it's simpler. Then you're only messing with one other 240v circuit, instead of moving around four other 120v circuits using twin breakers to make room for that 2p 30 amp breaker.
Depends on Future & Current Needs. I am going to have to go with either a Sub, or call the company that installed the panel in our house before we closed the sell, due to no space to put in a breaker for a A/C unit, and needing to add a couple for outside outlets, and Basement. I have pretty much used every space but one on my Square D Homeline.
Square D homeline panels will accept quad breakers that have two 15 amp single pole, or two 20 amp single pole on the outside poles, and a two pole of 20, 30, 40, or 50 amp on the two inside poles. This is a very easy way to get a 240 volt circuit from an existing panel that's full.
The big-box stores have them, make sure you look at the homeline type, not the QO.
I will have to look at Menards & Lowe's again, otherwise will have to make a call & pay a service charge to get one from an Electrician. Found the Tandem @ lowes.com, but still not the other.
US Electric is not that far. When I did my garage, I was thinking as the OP, but decided because of the size of the structure, that adding a 220 for a compressor was not enough of a need, but put on a list of future wishes. I am in the same boat as the OP, so hopefully adding on helped them with where they need to go in the right direction.
Well what I end up doing was getting a plug (same as my dryer) and wired the compressor up to this plug so now when i need to use the air compressor I just unplug the dryer and plug in the air compressor. Since the clothes dryer uses the same size breaker (dual 30amp), this was the easiest thing to do.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
