220v Breakdown - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 10:41 PM   #1
220v breakdown
If we have a 220v outlet with only three wires going in but need to break it down to two 120v's with four wires to power up a hot tub.Can the two "hot" wires be put together at the plug to then split it at the tub panel?
janieluna is offline   Reply With Quote
Old 07-23-2011, 10:47 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
No!
You need 4 wires from the panel.
Old 07-23-2011, 11:09 PM   #3
Rewards Points: 1,016
Welcome!
Nope, as JBfan commented you need 4 wires, not just the three. You need two hots, a nuetral, and ground.
____________
Vince
Old 07-23-2011, 11:16 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,098
You can only use a 220v outlet with at least 4 pins,
You cannot use a standard recepticule.
You need at least four wires to the hot tub
A standard rececticule only has three.
Sorry no can do !
dmxtothemax is offline   Reply With Quote
220V & 110V outlets rickinnocal Electrical 21 05-13-2011 02:16 PM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 11:46 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
question about 220V cd player vs 120V sdipiet@msn.com Electrical 2 11-25-2007 04:23 AM
