220v 50Hz Tool On 240v 60hz Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 03:41 PM   #1
Rewards Points: 508
220v 50Hz Tool on 240v 60hz circuit
What might be the consequences of running a German heat gun on a US 240v circuit? I don't imagine the difference in frequency would be much a problem for the blower motor. My concern is that the German device is not designed for split-phase power. What is likely to happen if I plug this guy in?
benjamincall is offline   Reply With Quote
Old 08-29-2013, 04:07 PM   #2
Rewards Points: 3,130
How are you going to plug it in? I can't imagine the German plug fits any American receptacle.
Old 08-29-2013, 04:10 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
It should work fine. The only significant difference is that both of the conductors will be at 120V with respect to ground instead of one being 240V to ground and the other zero. This could theoretically create a safety issue if the device relies in some way on the neutral conductor being "neutral" - but modern safety standards do not allow manufacturers to treat the neutral as "safe", because of the possibility of connection to a reverse-wired source. So if the device is newer and in good condition, it should be safe on split-phase power. People do this all the time, for what it's worth.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following 3 Users Say Thank You to mpoulton For This Useful Post:
benjamincall (08-29-2013), ddawg16 (08-29-2013), Kyle_in_rure (08-29-2013)
Old 08-29-2013, 04:33 PM   #4
Rewards Points: 508
That's the easy part. I'll either put a new plug on the end, or I'll use an adapter like this one to go from from a CEE 7/4 plug to NEMA 6-20 receptacle:
http://www.adaptelec.com/wa21-travel...q2q5l2pj8438n2
Cool. Thanks for the thorough explanation.
International Electrical Question..60HZ vs 50HZ Supply woodworkerjeff Electrical 9 08-03-2011 04:35 PM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
Circuit Tracing Tool hubbard53 Electrical 18 11-08-2007 07:51 AM
