-   -   220v 50Hz Tool on 240v 60hz circuit (http://www.diychatroom.com/f18/220v-50hz-tool-240v-60hz-circuit-186169/)
benjamincall 08-29-2013 03:41 PM
What might be the consequences of running a German heat gun on a US 240v circuit? I don't imagine the difference in frequency would be much a problem for the blower motor. My concern is that the German device is not designed for split-phase power. What is likely to happen if I plug this guy in?
md2lgyk 08-29-2013 04:07 PM
How are you going to plug it in? I can't imagine the German plug fits any American receptacle.
mpoulton 08-29-2013 04:10 PM
It should work fine. The only significant difference is that both of the conductors will be at 120V with respect to ground instead of one being 240V to ground and the other zero. This could theoretically create a safety issue if the device relies in some way on the neutral conductor being "neutral" - but modern safety standards do not allow manufacturers to treat the neutral as "safe", because of the possibility of connection to a reverse-wired source. So if the device is newer and in good condition, it should be safe on split-phase power. People do this all the time, for what it's worth.
benjamincall 08-29-2013 04:33 PM
That's the easy part. :) I'll either put a new plug on the end, or I'll use an adapter like this one to go from from a CEE 7/4 plug to NEMA 6-20 receptacle:
http://www.adaptelec.com/wa21-travel...q2q5l2pj8438n2
Cool. Thanks for the thorough explanation.
