220v 50A To 110v 20A - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2009, 04:54 PM   #1
220v 50A to 110v 20A
I just removed a spa that was powered by a dedicated 50A 220v circuit on a GFCI breaker. I want to convert the curcuit to 2 110v 20A circuits to power an outdoor ceiling fan and lights and a a refrigerator and beer keg cooler. Can I do this without running a new circuit?
toolman12002 is offline   Reply With Quote
Old 07-13-2009, 05:38 PM   #2
Licensed electrician
Rewards Points: 1,608
If this was a straight 240 volt circuit you would only have 2 hots and a ground. You couls possibly change this to one 120 volt circuit.
Describe the color and number of wires.
Old 07-13-2009, 06:54 PM   #3
Idiot Emeritus
Rewards Points: 1,492
Hot tubs are almost always 4 wire. Two hots, a neutral, and a ground. If this is the case, you can install a sub-panel and get both 120 and 240 from it.
If there is a small panel already near where the hot tub was, you can very likely remove the 50 amp 2 pole GFI breaker and install two single pole 120 volt breakers.
As stated above, if there's only 3 wires, you can re-connect one of them and get 120.
Rob
micromind is offline   Reply With Quote
Converting 220v dryer to 110v dbielinski Appliances 17 09-05-2012 05:45 PM
Adding 110V outlets to 220V line MarcG Electrical 25 04-29-2009 06:04 AM
Convert 220V to 110V wrldruler Electrical 13 09-15-2008 11:55 AM
110v vs. 220v gunboatbay Electrical 17 05-15-2008 08:09 AM
220v from 110v leboyd Electrical 6 03-19-2006 08:51 PM
