220v To 2 110v ? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2007, 04:38 PM   #1
220v to 2 110v ?
I have a 220v line that is not used for anything (gas dryer) but could use some more power in the att. garage, can I split the unused 220v line into 2 regular 110v lines 1 for lights and 1 for plugs. I think this is pretty simple but wanted a second opinion. Thanks Adam
Astoldt is offline   Reply With Quote
Old 12-28-2007, 04:41 PM   #2
Rewards Points: 900
If the line has 4 conductors - 2 hots a neutral and a ground, yes.
LawnGuyLandSparky is offline   Reply With Quote
Old 12-28-2007, 04:48 PM   #3
I was going to take it right from the box so yes 2 hots,black-red, a neutral, white and a ground at the bar in the box I was just worried about the shared neutral. Adam
Old 12-28-2007, 06:29 PM   #4
The connection at the point where you split the neutral is CRITICAL. Make SURE it's 100% tight or you can end up with 240volts to your lights/outlets
220/221 is offline   Reply With Quote
Old 12-28-2007, 07:15 PM   #5
Thanks. Adam
Old 12-28-2007, 09:16 PM   #6
Make sure you drop the breaker size down to a 20A(2pole) if you run 12 gauge wire from the junction point.
jerryh3 is offline   Reply With Quote
Converting 220v dryer to 110v dbielinski Appliances 17 09-05-2012 06:45 PM
question about 220V cd player vs 120V sdipiet@msn.com Electrical 2 11-25-2007 04:23 AM
Help on installing a 220v outlet BobRankin Electrical 24 10-23-2007 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
220v from 110v leboyd Electrical 6 03-19-2006 09:51 PM
