220V 15A Outlet In Garage - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 04:35 PM   #46
Originally Posted by Julius793 View Post
Your the one who doesn't work in the field and therefore have no clue what your talking about. Anything that is made in the states to be installed single phase will be rated for 120v or more.
Their rated for 125 not 120. And NOT all receptacles are rated for that. You are mistaken in that.
jasin is offline   Reply With Quote
Old 01-23-2012, 04:36 PM   #47
Julius793's Avatar
What do you work as?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-23-2012, 04:40 PM   #48
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by jasin View Post
You work in the electric field and yet, do not understand the dangers of overvolting and/or going beyond maximum ratings?
Im no expert like you jasin,but it seems like ive heard somewhere that certain motors like to run at voltages up to around 10-12% higher than normal.
But again ill wait for you to make that call for us!
plummen is offline   Reply With Quote
Old 01-23-2012, 04:43 PM   #49
plummen's Avatar
Hes working his way through maintenance college ,remember?
Old 01-23-2012, 04:45 PM   #50
Julius793's Avatar
that was my first guess my second will be a home inspector and third will be an EE that know **** . Well anyway got to go now have to find my troll spray
Old 01-23-2012, 04:48 PM   #51
plummen's Avatar
They must have booted him off military.com again!
Old 01-23-2012, 05:48 PM   #52
Licensed electrician
Rewards Points: 1,884
I notice a lot of people on here still say 110 and 220 but that's incorrect. The nominal voltage in the USA is 125 and 250.
The nominal voltages are 120 and 240.
Devices have the 125 and 250 volt ratings.
Speedy Petey (01-26-2012)
Old 01-23-2012, 05:51 PM   #53
Sub-panel is a very good idea/suggestion. He probably would only need too, a 60 amp panel at most. That may, however, overload the main panel. If the main panel has a dryer, furnace, AC, etc. on it, then having a 60amp sub-panel will most likely overload the main. Also, if he has a sub-panel he will need a sub-panel with a built in cut off / interrupt switch; I believe that is require by code.
A disconnect means would only be required if the sub was in a detached building and had 6 or more breakers. It would not be needed in an attached structure.
A single circuit to a detached structure could have a toggle switch as a disconnect.
Old 01-23-2012, 06:00 PM   #54
If he does not have 6 or more and there is no possibility of future upgrades or additions being added then a sub-panel is really pointless.
http://www.ci.bloomington.mn.us/hand...3fffdetach.pdf
He really has not given us to many specifics though so its all speculation as to what would work best in his particular situation.
Old 01-23-2012, 06:12 PM   #55
I meant 120 / 240. You are correct though.
Old 01-23-2012, 06:28 PM   #56
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
We seem to have lost the point that the OP has a welder or compressor with a 20 amp plug. It should be wired to a 20 amp circuit (20 amp receptacle, #12 wire and a 20 amp breaker). He should not install a 20 amp receptacle on his existing 15 amp circuit.
Coastal South Carolina
Old 01-23-2012, 06:33 PM   #57
What are you talking about? If a single circuit does not meet the needs a subpanel is the only option.
Old 01-23-2012, 06:34 PM   #58
That's exactly what I was saying.
Old 01-23-2012, 06:36 PM   #59
If he has 12 gauge wiring he can upgrade to a 20 amp braker NO problem. That was not his question though. He was asking about using a 20 amp outlet, I think he means ... "receptacle", on a 15amp circuit. And that is perfectly fine, he can do that. No code violations there.
Only problem is in upgrading the breaker to 20amp when only having 14 gauge wiring. He did not say he is doing that. At least, not from what I read.
You know, it really helps if we all use the correct terms. Receptacles and outlets are two different things. We should not use the term "outlet" in reference to a receptacle.
Old 01-23-2012, 06:45 PM   #60
Oh really?
European 220v Tools use with US 220v Outlet dominator Electrical 20 08-02-2012 11:21 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
de-activate 220v electric stove outlet 6fthook Electrical 17 10-04-2011 06:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
