220V 15A Outlet In Garage - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 05:20 PM   #31
Originally Posted by plummen View Post
So how is this going to affect me at 2 in the morning when i get 119 volts at the ssy on a furnace im working on should i be scared?
Ive done some of my best welding over the years running a 240v stick welder off of 277v,is that a bad thing?
You can put 110 volts into a device rated for 125 volts. There is no problem with that as its rated for more then you are supplying it with. You cannot, however, do the reverse. At least, not safely; NOT unless you are somehow stepping down the voltage.
jasin is offline   Reply With Quote
Old 01-23-2012, 05:20 PM   #32
Julius793's Avatar
Lucky it was 119v if it was nominal 125v I may have killed you
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-23-2012, 05:23 PM   #33
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by jasin View Post
Sub-panel is a very good idea/suggestion. He probably would only need too, a 60 amp panel at most. That may, however, overload the main panel. If the main panel has a dryer, furnace, AC, etc. on it, then having a 60amp sub-panel will most likely overload the main. Also, if he has a sub-panel he will need a sub-panel with a built in cut off / interrupt switch; I believe that is require by code.
The number and size of branch circuits will not overload the main breaker,its the number of items actually being used at any one time you have to watch
plummen is offline   Reply With Quote
Old 01-23-2012, 05:23 PM   #34
Can you give me an example?
You work in the electric field and yet, do not understand the dangers of overvolting and/or going beyond maximum ratings?
Old 01-23-2012, 05:24 PM   #35
plummen's Avatar
Are you sure about that?
Im thinking amperage is a bigger safety issue than voltage
Old 01-23-2012, 05:26 PM   #36
plummen's Avatar
Im just an old retired guy,always willing to take lessons.
Old 01-23-2012, 05:26 PM   #37
@plummen
You remind me a lot of the people who plug 25 devices into one receptacle and power strips into power strips.
Old 01-23-2012, 05:27 PM   #38
Julius793's Avatar
Of course I was joking as you said volts don't kill, amps do
Old 01-23-2012, 05:27 PM   #39
plummen's Avatar
So hows that maintenance job going?
Old 01-23-2012, 05:29 PM   #40
plummen's Avatar
Sorry I didnt look at the name,thought it was jasin posting again!
Old 01-23-2012, 05:30 PM   #41
Julius793's Avatar
Your the one who doesn't work in the field and therefore have no clue what your talking about. Anything that is made in the states to be installed single phase will be rated for 120v or more.
Old 01-23-2012, 05:30 PM   #42
plummen's Avatar
@plummen
Thats why I need guys like you to set me straight,for my own good!
Old 01-23-2012, 05:30 PM   #43
Cone on, use your brain.
A receptacle for example, wont supply 125 volts to a device if there's only 119 volts going to it. And a receptacle that has 119volts going to it when the nominal voltage is 125 is because the voltage is being stepped down somewhere NOT because, as you claimed, the nominal voltage is not 125.
Like I said though, that is not what I was speaking of. I was speaking of the reverse. You seem to not understand that though. That does not surprise me though as you are just trolling.
Old 01-23-2012, 05:32 PM   #44
plummen's Avatar
What are you talking about?
Old 01-23-2012, 05:34 PM   #45
Julius793's Avatar
Oh you mean receptacles won't add the 6v for you? Well then how can your appliance work?
European 220v Tools use with US 220v Outlet dominator Electrical 20 08-03-2012 12:21 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
de-activate 220v electric stove outlet 6fthook Electrical 17 10-04-2011 07:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
