220V 15A Outlet In Garage - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 03:42 PM   #16
Originally Posted by plummen View Post
If youre running a lot of stuff like compessors and welders in your garage have you thought about possibly just adding a sub panel in the garage to make it easier to upgrade your wiring out there as you add more big tools to your play area?
Sub-panel is a very good idea/suggestion. He probably would only need too, a 60 amp panel at most. That may, however, overload the main panel. If the main panel has a dryer, furnace, AC, etc. on it, then having a 60amp sub-panel will most likely overload the main. Also, if he has a sub-panel he will need a sub-panel with a built in cut off / interrupt switch; I believe that is require by code.
jasin is offline   Reply With Quote
Old 01-23-2012, 03:58 PM   #17
Originally Posted by Julius793 View Post
Yes and they will continue to do so
But it creates safety problems.
Old 01-23-2012, 04:00 PM   #18
Julius793's Avatar
Originally Posted by jasin
But it creates safety problems doing so.
Really? Which problems does it create?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-23-2012, 04:03 PM   #19
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by jasin View Post
I notice a lot of people on here still say 110 and 220 but that's incorrect. The nominal voltage in the USA is 125 and 250.
Depends on what part of town youre in,voltage can varie block to block
plummen is offline   Reply With Quote
Old 01-23-2012, 04:03 PM   #20
15 extra volts.
Old 01-23-2012, 04:05 PM   #21
plummen's Avatar
How is that creating a safety problem?
Old 01-23-2012, 04:05 PM   #22
But those are still the nominal voltages here in the USA. Any voltage differences that exist are because of voltage drops, differences in transformer ratings, etc.
Old 01-23-2012, 04:06 PM   #23
Julius793's Avatar
15 extra volts.
What the hell does that mean?
Old 01-23-2012, 04:10 PM   #24
Mixing up voltages is not safe. Things have ratings for a reason.
Old 01-23-2012, 04:11 PM   #25
You can't do simple arithmetic???
125-110 = 25.
Old 01-23-2012, 04:12 PM   #26
Julius793's Avatar
You clearly don't work with electric.
Old 01-23-2012, 04:13 PM   #27
Julius793's Avatar
125-110 = 25.
Yea 25v
Old 01-23-2012, 04:16 PM   #28
plummen's Avatar
So how is this going to affect me at 2 in the morning when i get 119 volts at the ssy on a furnace im working on should i be scared?
Ive done some of my best welding over the years running a 240v stick welder off of 277v,is that a bad thing?
Old 01-23-2012, 04:17 PM   #29
Yea 25v
Overvolting a circuit or device is very dangerous.
Old 01-23-2012, 04:18 PM   #30
plummen's Avatar
Can you give me an example?
European 220v Tools use with US 220v Outlet dominator Electrical 20 08-02-2012 11:21 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
de-activate 220v electric stove outlet 6fthook Electrical 17 10-04-2011 06:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
