-   -   220v to 120v (http://www.diychatroom.com/f18/220v-120v-1331/)
blwjrma71 11-20-2005 09:41 AM
220v to 120v
HI I'am currently changing my closet where I used to have a washer/dryer into a small office. I have a 220v outlet that was used for the dryer in the closet. I wanted to know if I can take the 220v outlet out and put in a 120v outlet instead? Thanks!
jproffer 11-20-2005 05:42 PM
Short answer...NO
Longer answer...maybe, but I wouldn't recommend a DIY'er trying to split 240 into 120. Call an electrician.
K2eoj 11-20-2005 06:19 PM
I'll go out on the thin ice and say "yes" until speedy or jbfan come along. Your dryer probably had a #10 wire with black white and ground. It should be a straight run to the panel. It seems to me if you take out the 240, (double) breaker and replace it with a 20amp single and connect the white to the neutral bar the only issue is that your #10 is oversized. Oversized wire is becoming an issue in our area because of what future people might hook up to it. We used to oversize quite a bit on remodels and although I can see the nec's reasoning I'm not going to go around downsizing on my house. Again that is just my thoughts until the real electricians come along. HS
jproffer 11-20-2005 06:34 PM
As long as you cut the exposed red conductor out and mark the wire clearly as 2 cond. cable. That's what I meant by "maybe...but..............."
jbfan 11-21-2005 07:43 AM
It depends on what wires you have now. Is it a 3 wire or 4 wire plug. As stated above, yoou can remove the two ploe breaker, reduce to a 20 single pole breaker, then you can splice some #12 onto the #10 in the oulet box and conect to the outlet. If you have 4 wire, remove the red wire, and cap it of with a wire nut, do not cut it, you may want to use the 240v again.
