220v To 120 - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 10:48 AM   #1
220v to 120
I want to buy a small 3200W generator for emergencies, but I don't really need the 220 outlets most of them have, I want to run mainly 120. But most generators this size have 2 outlets 120, and one 240. How can a run mutliple 120's on the 240 plug?
msowell is offline   Reply With Quote
Old 08-30-2009, 11:01 AM   #2
I think the only way is to setup a small sub that could be plugged in
But with a 3200 watt you have 26a amps of power @ 120v
And only 13a @ 240v - not enough to justify a small sub really
So if you have (2) 120v 20a plugs that is more then enough power
IE - that's all the power available from the generator
Old 08-30-2009, 11:03 AM   #3
You could get something like this:
http://www.amazon.com/L14-30P-250V-P...648303&sr=8-34
jerryh3 is offline   Reply With Quote
Old 08-30-2009, 11:06 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by msowell View Post
I want to buy a small 3200W generator for emergencies, ...... How can a run mutliple 120's on the 240 plug?
If nothing is connected to the 240 tap, 3200W is all available at the 120V outlet. Contact the manufacturer for more detailed data.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-30-2009, 11:16 AM   #5
Rewards Points: 236
Unless your house is all gas, I would consider a larger generator, and use only the 230 volt receptacle. But you said you wanted small and 3200 watt is small.
Old 08-30-2009, 11:16 AM   #6
By emergencies you mean if you lost power in your house?
That unit is a tad to small to power the necessities in your home (i.e. Frig, heat, couple of lights) simultaneously.
You should get something a little bigger.
ChristopherSprks is offline   Reply With Quote
Old 08-30-2009, 07:14 PM   #7
Exactly what I was looking for!
Michael
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
220V Wiring Mdbuilder Electrical 18 07-10-2008 11:14 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
question about 220V cd player vs 120V sdipiet@msn.com Electrical 2 11-25-2007 03:23 AM
Help on installing a 220v outlet BobRankin Electrical 24 10-23-2007 05:32 PM
