-   -   220v from 110v (http://www.diychatroom.com/f18/220v-110v-2064/)
leboyd 03-18-2006 02:26 PM
220v from 110v
I have a portable 220v 50a welder. Generally, I disconnect the electric dryer and run the welder through the window of the laundry room.
It recently occurred to me that I might be able to join two incoming 110v 30a outlets for the power. If I take in the input from 2 different areas of the garage, I will have the amps available.
I would make a 12g extension cord with two 110v males to the 220v female for the welder.
Does this make any sense?
TIA,
Rehabber 03-18-2006 02:41 PM
ABSOLUTELY NONE This would be a violation of code and inherebtly unsafe -- It would probably be a relatively simple job for a licensed electrician to a wire an outlet and add a subpanel if necesary
leboyd 03-18-2006 02:44 PM
Yep, it's not a big problem to add the 220v plug in the garage, and I figured that would be the only way, but just wnated to check before I didn.
Speedy Petey 03-19-2006 06:58 AM
I just wonder why you though a 30 amp circuit would be OK for a 50 amp device, and also why #12 would be good for EITHER?
Run a new 50 amp 2-wire, with ground, circuit to where the welder will be used. It's the ONLY safe and correct thing to do.
leboyd 03-19-2006 12:57 PM
I obviously wasn't clear enough in my thought process. Picture two extension cords ending at one 220v plug. Each cord would be plugged into a 30a outlet on a *different* circuit.
And ur right, the 12g wouldn't work. It would take 8g.
jproffer 03-19-2006 08:51 PM
That would only work (unsafe as it may...or WOULD..be) if the two cords came from opposite phases in the panel.
AND....if one breaker tripped and the other didn't, you're running a 220 welder off of 110 power. Few minutes of that and you now you have a $1500 (or however much it was) door stop...and a bunch of welds that aren't really welded...just...:rolleyes: ...hot.
