220 Wiring Help Oven - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2016, 10:58 PM   #1
220 wiring help oven
Hey guys I'm wondering if you could help me out with wiring up an oven.
I'm only using the oven periodically for Powdercoating.
What all would I need breaker/outlet/wiring size-type etc? Also I would like to make a 10-15ft extension cord for the oven so I could move it outside the garage if I wanted when coating.
Any help would be greatly appreciated!
Thanks!
gotboosthatch is offline   Reply With Quote
Old 04-27-2016, 11:01 PM   #2
Rewards Points: 774
Re: 220 wiring help oven
Thanks!
Name plate data from the oven would be helpful, Voltage, amperage, KW.
Know A Little is offline   Reply With Quote
Old 04-27-2016, 11:01 PM   #3
joed's Avatar
Rewards Points: 11,506
A typical range needs 6/3 NMB cable, 40 amp double pole breaker and a 40 amp stove receptacle.
Your extension cord should be 6/4 type SO cable.
Old 04-27-2016, 11:02 PM   #4
Any videos or diagrams on how to install?
Old 04-28-2016, 07:37 AM   #5
Licensed electrician
Rewards Points: 996
Is this an oven or a range ?
Old 04-28-2016, 10:23 AM   #6
It's a range with top burners but I won't be using them at all only the oven
wiring a built-in electric conection oven leemar Electrical 1 09-27-2010 11:05 AM
Cooktop and Stand Alone Oven Wiring Replacing Existing Single Range/Stove Combination ffauth Electrical 3 08-23-2010 10:03 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 06:55 AM
Wiring Cooktop and Under Counter Oven Preach_2 Electrical 18 03-19-2009 05:30 PM
oven wiring stan 41943 Electrical 8 03-24-2008 09:26 AM
