220 Wall Heater Wiring To A Timed Or Spring Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 04:40 PM   #1
220 wall heater wiring to a timed or spring switch
I added a bathroom to the garage because I am usually too dirty to use the house - so I am told. Anyway, pulled all permits etc so will be inspected. The heater will be wired as 220 (tho has option for 115), and has a thermostat control switch but I also like to have a timed switch or spring switch as well so it won't kick back on later as it could with a thermostat only control. Can I just wire one hot lead of the 220 to the switch while passing the white and red on thru to the heater. I assume this will work for a timed shut off as can use a spring loaded switch or one with 5-10-15-30 minute options. Thanks for any help you can provide.
zacman44 is offline   Reply With Quote
wiring fan, light, heater another light and GFCI Cvolpe Electrical 11 05-16-2012 07:13 PM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Figuring Out Panamanian Switch Wiring machodelmonte Electrical 5 05-16-2011 07:33 AM
Wall switch wiring for ceiling fan Rusty Nail Electrical 2 04-25-2011 01:34 PM
What switch to install between panel and 220 volt heater Rogers Guitar Electrical 4 01-21-2009 06:08 PM
