-   -   220 wall heater wiring to a timed or spring switch (http://www.diychatroom.com/f18/220-wall-heater-wiring-timed-spring-switch-165015/)
zacman44 11-28-2012 05:40 PM
I added a bathroom to the garage because I am usually too dirty to use the house - so I am told. Anyway, pulled all permits etc so will be inspected. The heater will be wired as 220 (tho has option for 115), and has a thermostat control switch but I also like to have a timed switch or spring switch as well so it won't kick back on later as it could with a thermostat only control. Can I just wire one hot lead of the 220 to the switch while passing the white and red on thru to the heater. I assume this will work for a timed shut off as can use a spring loaded switch or one with 5-10-15-30 minute options. Thanks for any help you can provide.
