220 Volt Switch For Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2008, 12:57 PM   #1
220 volt switch for compressor
I have an air compressor (220v) that used to be hard wired into a house (before I bought it). The guy I bought it from changed it over, so now it has a 220 plug on it. But it doesn't have an on/off switch. Where can I buy a 220volt on/off switch? What type of switch is it?
The only thing I could find at Home Depot looked like a miniature breaker box with 2- 30 amp fuses. It was a big disconnect switch about 8 1/2" tall with an on/off lever on the side. Is this what I need?
Here is a pic of it
http://www.electric-supplier.com/pro...1n_w243361.php
powers is offline   Reply With Quote
Old 08-18-2008, 01:15 PM   #2
Electrical Contractor
That will work.
hpp58 is offline   Reply With Quote
Old 08-18-2008, 03:25 PM   #3
Here is a pic of it
Here in Canada, Home Depot carries a 220 volt/30 amp breaker box. Something of this nature must be available in your area.
I recently bought one for my cottage a/c. The 30 amp breaker is extra!
Old 08-18-2008, 03:44 PM   #4
joed's Avatar
Rewards Points: 12,026
You should be able to get that same thing without the fuses. It's called an unfused disconnect.
Old 08-18-2008, 08:57 PM   #5
Idiot Emeritus
Rewards Points: 1,492
If it's 2HP or less, a 20 amp 2 pole light switch will work. Sometimes you can find a 30 amp one that is rated at higher HP, just look on the box or the switch itself to see what HP it can handle.
Rob
micromind is offline   Reply With Quote
Old 08-18-2008, 11:13 PM   #6
Thanks for the help guys!
Old 08-19-2008, 12:03 AM   #7
Cow
I agree with Micro. Look for some 2 pole motor rated switches, coincidentally I just installed a few yesterday. I know they come in 20 and 30 amp sizes, they look like a heavy duty light switch.
Cow is offline   Reply With Quote
Old 08-19-2008, 12:38 AM   #8
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
are you talking about a pressure switch since it is plugged in I take it that that is what you are talking about but I could be wrong. Since it is plug and cord you can just unplug it to disconnect.
Pudge565 is offline   Reply With Quote
Old 08-19-2008, 11:19 AM   #9
No, it's got a working pressure switch. It just doesn't have a on/off switch. I wanted to wire one up so I can just leave it plugged in and hit the switch to turn it on. The plug is right behind the compressor, so it's a pain in the butt to get to.
Old 08-19-2008, 11:20 AM   #10
Is this something I can get at home depot? The people that work there don't know too much, so I try to do my homework before I go. Thanks a lot!
Old 08-19-2008, 12:53 PM   #11
You can use a double pole switch
You can find this switch at :
http://www.gordonelectricsupply.com/index.jsp?path=find
Here is a pic of it
Woodyh1 is offline   Reply With Quote
Old 08-19-2008, 01:05 PM   #12
Rewards Points: 82
Go to an electrical supply house and get a 30 amp double pole switch. One that will fit in a regular switch box. Mount your switch in a convenient location and use the receptacle you are plugged into for the power.
You can use a single pole switch if you cannot find the 2 pole. Just switch one wire like it is in the pressure switch.
Try to find the double pole switch, with the single pole, one wire will always be hot to the pressure switch.
The blade switch above will work just fine and may even be less money than the snap switch.
PS.....Doesn't the compressor have an on/off switch?
Old 08-19-2008, 05:04 PM   #13
No. It was hardwired into a house circuit. Then the previous owner installed a plug w/out a switch.
Old 08-20-2008, 12:12 PM   #14
Rewards Points: 82
The reason I asked you is because mine has a switch located right at the pressure switch.
Old 08-20-2008, 01:52 PM   #15
Rewards Points: 150
hard wire and use the breaker to turn on and off
comp is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
