220 Volt Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 11:34 AM   #1
Rewards Points: 47
220 volt outlet
I have an exposed 110 volt wire colored white that an electrician put in for some outside lights. That was never done but the wire is still there. I also have two yellow wires coming from the breaker box. These and the white are within six feet of where I would want the 220 outlet. Can you make a 220 from either of these scenarios? Also, the breaker box is just on the other side of an outside wall with a 110 outlet already there. I can gain access to that outlet through the sheetrock, so could that be converted to 220? thanx
jeffs55 is offline   Reply With Quote
Old 01-15-2013, 12:48 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
Not enough info.
There is no such thing as 240 volt outlet without know the amperage required.
Do you need a 120/240 circuit or just a 240 volt circuit?
Do you need 20/30/40/50 amps?
The white and yellow wires, are they cables or individual wires?
Switched Outlet Issue mjm Electrical 13 06-14-2015 08:56 PM
Outdoor Outlet seansy59 Electrical 3 03-09-2012 04:50 PM
Add An Outdoor Outlet pokey302 Electrical 3 02-21-2011 09:46 AM
Should I replace a 240 volt outlet when getting a new AC sxn77 Electrical 18 05-08-2009 12:23 PM
Can I run two 220 volt devices off of one outlet stringpickin Electrical 39 04-26-2009 01:48 PM
