220 Volt Electrical Wiring Question ... For Light ??? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 10:04 PM   #1
220 Volt Electrical Wiring Question ... for light ???
I have a areana light that is 220 Volt .... and I would like to use it . It will be wired to straight 220 Volt .... Question is ... there are 5 wires coming out of the light ... What ones do I wire to ????
The 5 wires are marked .....
Comm
120V
208V
240V
277V
Which do I use ...
Thanks... Doug
shotguns is offline   Reply With Quote
Old 05-20-2011, 10:07 PM   #2
Sparky
Rewards Points: 510
240+common
Techy is offline   Reply With Quote
Old 05-21-2011, 07:10 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
No, what you have is a multi-tap ballast fixture.
No, it will be wired to either 208v or 240v. Which one is it?
Comm
120V
208V
240V
277V
Which do I use ...
My initial instinct is to tell you that if you have to ask this you should NOT be doing it, but I know I will be told "This is the DIY forum, blah, blah, blah,...."
Tell us the actual voltage.
Is this in a residential setting or otherwise?
Old 05-21-2011, 07:29 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Good call Speedy
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Speedy Petey (05-21-2011)
Old 05-21-2011, 08:07 AM   #5
Rewards Points: 1,512
A circuit or load described as "220 volts" is in the 240 volt category, not the 208 volt category.
AllanJ is online now   Reply With Quote
Old 05-21-2011, 03:32 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,350
It would be much safer to underun the light at 240v setting,
Than to overun the light on 208v
Use the 240v setting.
The light will be quite happy running on 240v setting.
Comm
120V
208V
240V
277V
Which do I use ...
Thanks... Doug
dmxtothemax is offline   Reply With Quote
Old 05-21-2011, 05:56 PM   #7
Rewards Points: 93
Why not use the 120 volt and common taps, and use a 120 volt circuit? Shotguns didn't say where this lamp is being used, but I wouldn't want an odd-ball "220" volt fixture in a residential setting (unless in an area where 220 volt lighting and outlets are the norm, like some parts of Europe.)
Perry401 is offline   Reply With Quote
Old 05-21-2011, 06:19 PM   #8
How can you possibly say this with such certainty???
What if this is going in an apartment in NYC that has 120/208V power? (I know, not likely, but humor me)
What if it is going in a strip mall with 120/208V 3-phase power?
What if this IS going in an arena with 120/208V power???
I think the "220" thing is just a lay person's way of saying it. I don't think the OP has any idea what 208V is or if they even have it.
That said, he logged out the instant he make the original post. Are we taking bets whether he even shows back up to follow up??
Old 05-21-2011, 08:12 PM   #9
Rewards Points: 266
He did the same thing at self help. Kind of irritates me that many people post the same question at many forums and then never reply.
junkcollector is offline   Reply With Quote
Old 05-21-2011, 08:39 PM   #10
That worked
THAT WORKED ........... 240V . and Common .......
Thanks for the help ....
Doug
Old 05-21-2011, 08:41 PM   #11
OPPS ... forgot to add ...
The light went up in a large shop / barn ... and had 220v for welder and other stuff ...
Thanks again ... Doug
Old 05-21-2011, 09:03 PM   #12
....but is it right??
It would have worked at 208V as well.
Did you verify the voltage?
Electrical Wiring code - through Studs? mike6679 Electrical 7 08-11-2010 08:16 AM
Old Electrical Box Insurance Question bailey35 Electrical 4 06-29-2010 01:58 PM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
New fixture wiring question Unregistered Electrical 1 02-22-2004 07:34 PM
