220 Volt 50 Hz - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 10:11 AM   #1
Newly Retired
tuchodi's Avatar
220 volt 50 hz
I was given some German tools that are all 220 Volt 50hz. Can I use them on our North American 220 volt 60hz system. They all have just 2 round prong plugs which I can change if needed.
tuchodi is offline   Reply With Quote
Old 07-17-2010, 10:44 AM   #2
I use a Variac to drop the 240 v to 220 v but you may get reasonable tool lifetimes at the 240 v.
You might run them on long extension cords which will reduce the voltage slightly.
240 v puts 20% more power into the tool.
I e-mailed Metabo with this power question and I should be hearing back in a few days.
Old 07-17-2010, 01:06 PM   #3
Civil Engineer
Rewards Points: 4,938
I assume these are AC motors (no AC-DC converter in the tools), in which case I believe they are going to run 20 percent faster at 60 hertz than at 50 hertz.
Daniel Holzman is online now   Reply With Quote
Old 07-17-2010, 02:03 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you forgot to figure in the difference between 50 Hz and 60 Hz. It isn't just a voltage calculation when you are dealing with inductive loads.
Old 07-17-2010, 03:43 PM   #5
Newly Retired
tuchodi's Avatar
Yes they are all AC motors. A couple are variable speed so I though that the variable speed tools might work without any problem as far as extra speed from the 50hz to 60hz.
Old 07-17-2010, 04:44 PM   #6
Rewards Points: 1,548
The tools will probably work okay on 230-240 volts 60 Hz. They will run a little faster (RPM wise) and they may have a little less power output ( have less strength; produce less torque).
Unless the motors are "synchronous", some slippage, or loss of rotational synchronization with the power line frequency, occurs a fraction of a revolution at a time and this varies with load.
Do not go the other way, running 60 Hz motorized equipment on 50 Hz. Additional current draw possibly resulting in overheating can result.
Old 07-17-2010, 07:27 PM   #7
You're right.
6/5 ths more inductive reactance will give 5/6 ths of the current.
(5/6)(240/220)= 0.91
This is getting messy.
Old 07-17-2010, 08:18 PM   #8
Newly Retired
tuchodi's Avatar
Thanks for all the info.
As I was looking at the cord ends on the tools they only have 2 round terminals. My understanding is our 240 has three legs so how would I hook up the 2 wires to the new plug ends which have three terminals?
Old 07-17-2010, 08:29 PM   #9
nap
You talking to me?
nap's Avatar
does it have a metal tab along the side of the plug, like 90 rotation from either or both of the prongs?
If so, that is the ground connection. The two prongs are 1 neutral and 1 hot, if I remember their connections correctly.
sounds like something Marc (the French guy) can give a better answser.
The Following User Says Thank You to nap For This Useful Post:
frenchelectrican (07-18-2010)
Old 07-18-2010, 10:42 AM   #10
Yes, their ground connections are not too obvious. The tools are probably double-insulated.
And since the Germans are not dropping like flies from being electrocuted this is probably somehow OK, even with their higher voltage.
Old 07-18-2010, 10:52 AM   #11
Newly Retired
tuchodi's Avatar
Thanks for the info.
I will put new ends on the tools and later advise how everything works.
Old 07-18-2010, 10:53 AM   #12
I=E/R
a7ecorsair's Avatar
Do just one for starters and test it well.
Here are the two plugs used in Germany
a7ecorsair is offline   Reply With Quote
Old 07-18-2010, 06:27 PM   #13
nap
You talking to me?
nap's Avatar
the upper one is the one I was thinking of. The taps at the outer edge is a ground connection. I'm not familiar with the lower one. I guess it just doesn't use a ground connection.
Old 07-18-2010, 07:16 PM   #14
Newly Retired
tuchodi's Avatar
All my tools have the bottom looking plug.
Old 07-18-2010, 09:39 PM   #15
" Euro " electrician
frenchelectrican's Avatar
It is the simauir one we have in France as well.
As long the tool is double insulated it is not a issue at all.
But for other type of tools just becarefull some case you will find the netural is tied to ground so if you have grounding slot or pin the wise thing is get the ohmmeter to verify it before you ever get it engerized on North Americia 240 volt circuits.
Merci.
Marc
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 01:12 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 11:37 AM
VA (volt amps) Captflx Electrical 8 01-29-2010 02:15 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
