220 Volt 15A GFCI -- Where Does One Get A Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2008, 02:17 PM   #1
RippySkippy's Avatar
220 Volt 15A GFCI -- where does one get a breaker?
I'm getting ready to install a bubble tub (use air rather than water to create movement) the rated draw from the motor is 3A at 220/240V.
I thought "no problem" just pick up a GFCI breaker, pop it in and life's good. No such luck, I can't locate one. Is there such an item? If not, how else should I provide the GFCI protection for this device.
TIA!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 08-21-2008, 02:30 PM   #2
Whatamess
Can the motor be switched to 120V? The data plate will have a diagram if you can.
http://www.spaguts.com/Product.aspx?...FQoaswod8D-2kA
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-21-2008, 02:59 PM   #3
I don't believe so. And the link goes to the same thing I've been able to find...all sorts of 50+ amps...but not 15.
Thanks anyway!
LMASD
Old 08-21-2008, 03:14 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
Why not use a 20A? Did you wire it with #12 or #14?
Old 08-21-2008, 05:38 PM   #5
I haven't yet...so I can go either way.
LMASD
Old 08-21-2008, 06:43 PM   #6
What Brand/style panel do you have? Most common panel mfgs. offer these breakers, although they are pricey.
Square D offers QO series 2-pole GFI breakers in 15A, 20A, 25A, 30A, 40A, 50A, and 60A.
QO215GFI is the part number for a QO series, 2-pole, 15 amp GFI breaker.
Willis
williswires is offline   Reply With Quote
Old 08-21-2008, 06:55 PM   #7
215GFCB's are certainly made. Finding one is a different story.
220GFCBs are very common on the other hand.
Tags
220 , bubble tub , gfci
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 03:29 PM
New GFCI Breaker trips with no load bmurphywa Electrical 6 04-06-2008 09:48 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
GFCI outlet vs. breaker - GF trip speed LanterDan Electrical 2 01-09-2007 07:05 AM
GFCI breaker problems bwoo Electrical 5 12-09-2006 03:53 PM
