220, Two Wire, Hard Wire, To 4 Prong Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 10:41 AM   #1
grizzled
Question
220, two wire, hard wire, to 4 prong outlet
I am replacing an old two wire range that I have hardwired to the circuit. Fot the new dual fuel range, a 4 prong outlet is called for. I realize that an entire replacement run from the breaker box is called for. What do I do with the extra two wires?
jasesselstyn is offline   Reply With Quote
Old 11-27-2010, 11:20 AM   #2
Rewards Points: 1,668
Connect them to the panel and outlet as to their right places? Black and red to their own breakers, bare to ground bus bar, neutral white to neutral bus bar and then similar terminals on the outlet.
bob22 is offline   Reply With Quote
Old 11-27-2010, 11:49 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
If you are running a new circuit WHY would you have an extra two wires?
Old 11-27-2010, 11:51 AM   #4
Rewards Points: 204
You meant breaker right? Not breakers?
Old 11-27-2010, 11:53 AM   #5
grizzled
Thanks for quick reply, I have an older breaker box. Is it likely that I will have ground and neutal bus bars? Much of my house is knob and tube. I do have one grounded circuit that I set up 15+ years ago. I forget how I grounded itbut it is grounded for a three prong 120 outlet
Old 11-27-2010, 12:26 PM   #6
grizzled
Speedey,
The existing circuit has just two wires, I believe. The modern circuit has the neutral and ground along with the heat. Now I must open up my breaker box to see if I'm gifted with a neutral bus bar
Old 11-27-2010, 01:22 PM   #7
If you run a new circuit that will have everything you need. You CANNOT just run a 2-wire cable to add what you need.
If you run a new cable then just cap off (on both ends) and ignore the old cable.
Old 11-27-2010, 01:24 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
I know this is a DIY forum, but based on your terminology and lack of electrical basics: I recommend you hire an electrician.
Coastal South Carolina
Old 11-27-2010, 08:52 PM   #9
Yes; meant two separate terminals in a 2-pole breaker. Good clarification.
Old 11-27-2010, 08:59 PM   #10
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I think he meant the 2 new or additional wires.
Tags
220 , 4 wire , ground vs neutral
running wire underground for outdoor outlet ponch37300 Electrical 11 06-26-2009 09:41 AM
how to wire an outlet? dmoneyz Electrical 10 04-02-2009 01:21 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
compressor... to hard wire crecore Electrical 3 11-10-2007 12:02 PM
