A 220 Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 03:09 PM   #1
a 220 switch
i have a meat saw which is a 220 i have a switch with two brass screw and twoblackscrew which ia20volts switch how should i wire that switch
stanley bazile is offline   Reply With Quote
Old 06-17-2012, 03:11 PM   #2
wareagle's Avatar
Please correct this.
wareagle is offline   Reply With Quote
Old 06-17-2012, 05:14 PM   #3
Idiot Emeritus
Rewards Points: 1,492
A switch that controls a motor needs to be rated for both the HP of the motor as well as the voltage it operates at.
There is no code requirement for a control switch to open all hots, but it's generally a good idea to use a two pole switch to control a 240 volt motor. A two pole switch will have 4 terminals, a single pole has 2. A two pole switch breaks both hots, a single pole breaks only one.
Rob
micromind is offline   Reply With Quote
Old 06-17-2012, 05:20 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,968
But it's important to note that not all 4-terminal switches are double pole switches. Some are 4-way switches, and they look pretty much identical.
mpoulton is online now   Reply With Quote
Old 06-17-2012, 05:29 PM   #5
Idiot Emeritus
This is true, I was thinking of a basic toggle switch that mounts in a round hole, but light switches do indeed come in both versions.
Also, a lot of light switches don't have the HP rating stamped on them, you have to look in the manufacturers specbook.
Rob
Old 06-17-2012, 08:42 PM   #6
Master Electrician
Rewards Points: 3,916
They look alike but a 2 pole switch will say "on" and "off" if it is a toggle switch.
brric is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
