220 Single Phase 3 Wire To 4 Wire Stovetop - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 09:18 AM   #1
Cool
220 single phase 3 wire to 4 wire stovetop
Hi All,
I have a 220 single phase 10 gauge service with 3 wires.
White, Black, and Bare
I measure 247 volts acreoss the black and white and 125 accross
the black and bare.
The NEW stove has 4 wires.
White, Black, Red, and Green
As we have been abandoned by our contractors it looks like I need to do the finish work and need advice on the CORRECT connections for a direct hookup in a 4inch box. All of the posts I have read are NOT EXACTLY the same situation or configuration as in our home.
The wiring diagram for the new stove shows Black = L1, Red = L2,
White = N, and Green = Ground
Can someone tell me exactly what color goes to what in the box?
The cross talk, if, thens, and buts I have read to date have only added confusion. Plus the instalation guide keeps refering to a RED and Black coming from the service side and we DO NOT have a RED.
Thanks in Advance for your help.
bulldog55 is offline   Reply With Quote
Old 04-10-2012, 09:21 AM   #2
Licensed electrician
Rewards Points: 1,028
Your new unit requires a 120/240 circuit with 4 wires. You only have a 240 volt circuit with two hots and a ground. You do not have the neutral the new stove requires. Your white is actually a hot and should be re-identified as so with tape or magic marker.
Do you have the installation instructions? If so can you post them?
Old 04-10-2012, 09:53 AM   #3
Code05's Avatar
Rewards Points: 1,104
Is the wire that is there new or existing?
If existing is it NM or SE? white or gray.
Is it from a main panel or a sub?
Code05 is offline   Reply With Quote
Old 04-10-2012, 10:00 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would go after the contractor you hired to do the job. If you can't resolve it with them, I would hire someone to do it (just like you did in the first place), pay them, then sue the original contractors who left you high and dry. If you haven't already, contact your local building department, tell them what happened. They need to know that a contractor screwed you over so they can be on the lookout or help you resolve the problem.
Old 04-10-2012, 03:02 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,858
He says the gound wire is bare, so it was never compliant to use it as a current-carrying conductor. He needs to run a new circuit or choose a 240V-only appliance.
mpoulton is offline   Reply With Quote
Old 04-10-2012, 04:10 PM   #6
Update
Service Side: Stovetop Side:
Black Black
White Red
Bare White and Green
AGAIN I am looking for verification if this is correct..
Thanks,
rick
Old 04-10-2012, 04:13 PM   #7
k_buz's Avatar
Old 04-10-2012, 04:19 PM   #8
update 2
I did not see that so many responses below.
I will try to answer them now.
Do you want a link to the Electrolux Instalation guide or me to scan the instalation page that discusses how to wire it? Again it references to the service side having both a black and a red. (I don't have any red on service side)
The service side is existing from OLD stovetop.
The wire under the cabinet is inside a metal wound casing. I know where the circuit breaker is but I guss I would have to take off the whole front pannel to see the wires behind. As a kid I learned this is NOT and area to go exploring if newbie.
Old 04-10-2012, 04:27 PM   #9
DIY Enthusiast
sublime2's Avatar
What you have coming out of the wall is commonly referred to as 10/2 wire. (black,white&bare)
You NEED 10/3(black,red,white&bare) wire to power your new appliance.
sublime2 is offline   Reply With Quote
Old 04-10-2012, 04:28 PM   #10
K_Buz... I am NOT challenging you here just giving you FYI...
In the breaker box there are NOT two seperate blocks for white netrals and bare grond wires for all the 20 and 30 amp services they are ALL on
the same block.. Does this mean a problem or was it just the way things were at point of original construction?? BTW there is NOT a seperate block
in the breaker box as I have seen in pics since investigating my issue.
Old 04-10-2012, 04:29 PM   #11
k_buz's Avatar
Old 04-10-2012, 04:33 PM   #12
Although I have rread many threads that the 3 wire service to a 4 wire stovetop is allowed.. it sounds like this is a potential hazard correct?
The popular consensus seems to be go FIND a real electrician and have him run a new service line... Correct?
Old 04-10-2012, 04:34 PM   #13
DIY Enthusiast
sublime2's Avatar
You are correct,sir!
Old 04-10-2012, 04:36 PM   #14
Thanks to all I know my ignorance is upsetting to those of you who live and breath this stuff.
I really do appreciate your patience.
OFF to find my own electrician now...
Old 04-11-2012, 10:04 AM   #15
Code05's Avatar
Actually, the neutral/grounded conductor in 3 wire SE cable can be bare. If it was existing, and a SE cable, and terminated in a main panel, you could hook up the cook top.
Yes, they do make a 10-10-10 CU SE cable.
http://www.southwire.com/ProductCata...rodcatsheet274
The Following User Says Thank You to Code05 For This Useful Post:
k_buz (04-11-2012)
Converting single phase to three phase ogoa Electrical 13 02-05-2012 10:36 PM
How to find out if single phase or 3 phase? ogoa Electrical 9 02-05-2012 07:08 PM
heating element 240 volt single phase geeyathink Electrical 19 02-20-2011 07:57 AM
irrigation pump shutdownMy Sta-rite 2 HP centrifugal self priming single phase 240V i Oly Electrical 7 06-17-2010 11:44 AM
Converting std 220v/60hz to Single phase 240V 3-wire jryali Electrical 19 03-24-2009 12:06 AM
