220 Range Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 06:48 AM   #1
220 range outlet
i am changing a 220v outlet for a range, 3-wire , wiring already in place, everywhere i look it says one red , one white, one black, i have 2-blacks & a white, my question is, i know where the white goes of course, does it matter which black goes to which side? I dont think so i just want to make sure, they both should be hot, so it shouldn't matter right! I work with 110v all the time, never with 220v. If some one knows i would appreciate it!! Thanks!
house flipper is offline   Reply With Quote
Old 05-25-2009, 07:02 AM   #2
the Musigician
DangerMouse's Avatar
each black should be 110v with the white and it shouldn't matter which leg goes on which side.
use a voltmeter to test if unsure.
DM
Old 05-25-2009, 09:45 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Each black wire should read ~120V between it and the neutral, and ~240V between the 2 black wires. Coloring one of the black wires to Red is just for visual identification (on a 120/240V 1ph system). Color identification becomes important when dealing with 3ph systems.
Kyle
Old 05-25-2009, 10:12 AM   #4
Rewards Points: 160
At least you don't have a black, white and ground that seems to be commonly discussed on this forum. You have four wires and thats all that matters. However, it is unusual to see a cable colored like that. What does it say on the cable jacket? What type of cable do you have?
Old 05-25-2009, 11:06 AM   #5
I'm guessing conduit.
220/221 is offline   Reply With Quote
Old 05-25-2009, 11:13 AM   #6
Rewards Points: 160
Makes perfect sense to me.
Old 05-25-2009, 03:40 PM   #7
yes it is conduit, Thanks alot everyone i got the answers i need!!! THANKS AGAIN!!!!!
Replace Range Outlet Suncrest79 Electrical 22 04-14-2009 11:32 PM
Dryer outlet vs. Range outlet cindakay Electrical 24 04-13-2009 06:01 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 10:11 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 04:06 PM
