-   -   220 range outlet (http://www.diychatroom.com/f18/220-range-outlet-45201/)
house flipper 05-25-2009 06:48 AM
220 range outlet
i am changing a 220v outlet for a range, 3-wire , wiring already in place, everywhere i look it says one red , one white, one black, i have 2-blacks & a white, my question is, i know where the white goes of course, does it matter which black goes to which side? I dont think so i just want to make sure, they both should be hot, so it shouldn't matter right! I work with 110v all the time, never with 220v. If some one knows i would appreciate it!! Thanks!
DangerMouse 05-25-2009 07:02 AM
each black should be 110v with the white and it shouldn't matter which leg goes on which side.
use a voltmeter to test if unsure.
DM
SD515 05-25-2009 09:45 AM
Each black wire should read ~120V between it and the neutral, and ~240V between the 2 black wires. Coloring one of the black wires to Red is just for visual identification (on a 120/240V 1ph system). Color identification becomes important when dealing with 3ph systems.
J. V. 05-25-2009 10:12 AM
At least you don't have a black, white and ground that seems to be commonly discussed on this forum. You have four wires and thats all that matters. However, it is unusual to see a cable colored like that. What does it say on the cable jacket? What type of cable do you have?
220/221 05-25-2009 11:06 AM
I'm guessing conduit.
J. V. 05-25-2009 11:13 AM
Makes perfect sense to me. :thumbsup:
house flipper 05-25-2009 03:40 PM
yes it is conduit, Thanks alot everyone i got the answers i need!!! THANKS AGAIN!!!!!
