220 Range/dryer Outlet??? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 12:48 PM   #16
it is a rental. i also rent the property. the owner of the property gave me permission to do whatever i wanted with the garage. the original owner of this property lived in the garage and had tenants in the main house. i want to rent out this house to make expanses easier on my family. starting to think i should just go with a gas range and not even bother with a dryer outlet.
jeremy1979 is offline   Reply With Quote
Old 10-28-2012, 04:09 PM   #17
Originally Posted by joed View Post
The switch on the right is your main disconnect.
The range would be connected into the large block with the handle on the upper left of the fuse box. If that block is not being used then you can add the stove line. Otherwise you need to add a sub panel or replace the entire panel with one that has more spaces.
joe can you please PM me?
Old 10-28-2012, 04:57 PM   #18
Master Electrician
Rewards Points: 3,770
The lower right fuse block is empty but marked "AC". Check to see if those 35 amp fuses at the upper left aren't powering an AC unit.
brric is offline   Reply With Quote
Old 10-28-2012, 05:47 PM   #19
there is no a/c unit in or around the place unless it is buried underground. the only a/c unit on the property is attached to my house but it doesnt work
Old 10-28-2012, 06:54 PM   #20
joed's Avatar
Rewards Points: 12,018
Originally Posted by jeremy1979 View Post
are you an electrician joed?
NO and therefore I can not legally do any work at your house, if that is what were thinking.
You can not have the dryer and stove on the same circuit.
Old 10-28-2012, 07:51 PM   #21
Missouri Bound's Avatar
Originally Posted by jeremy1979;1039565[I
].....i have not had any attitude here. do you need help reading??? do you have the ability to open your mouth and treat people with decency and respect? i certainly have my doubts that you are qualified to do that. no one has had any helpful information???[/I]
So let me get this straight, buddy...you don't see any attitude in any of these statements?
Is this the way you always ask for help? Surprising if you get any at all. Maybe when you do get an electrician you can avoid telling him how superior you are! Just a thought..........
Do you want it your way or the right way?
Old 10-28-2012, 09:20 PM   #22
here is a picture of the panel i need 220 hooked up too
last question. if nothing is running on the current 250V slot.. can i hook up a range on than AND add a sub panel for a dryer? thank you
Old 10-28-2012, 09:33 PM   #23
Master Electrician
No. You might be able to add a subpanel off the existing panel and then add a range circuit and a dryer circuit off the subpanel. Load calcs need to be done to determinne if the existing service can handle the additional load.
Old 10-28-2012, 09:44 PM   #24
thanks. am i looking at spending a small fortune to get this ready for a tenant?
Old 10-28-2012, 10:05 PM   #25
Master Electrician
A reputable, qualified, local electrical contractor could more easily help you.
Old 10-28-2012, 10:22 PM   #26
thank you
Old 10-28-2012, 11:21 PM   #27
joed's Avatar
What size are the fuses in that disconnect? If they are 100 amp then you could install a new 100 amp panel for probably around $1000. If you DIY and get inspection probably around $500.
Old 10-29-2012, 08:46 AM   #28
100 amp fuses. that's just for the panel and all the circuits right? not counting the wires and outlets for both the stove and dryer?
Last edited by jeremy1979; 10-29-2012 at 09:47 AM. Reason: added more to my comment
Switched Outlet Issue mjm Electrical 13 06-14-2015 08:56 PM
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 07:37 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
