220 Range/dryer Outlet??? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 03:17 PM   #1
220 range/dryer outlet???
i have a detached garage fitted with a fuse panel that is connected to the main circuit breaker of the house. i am renting it out as it has it's own living quarters but it doesnt have a range outlet. can i hook up a 220 range outlet to the fuse panel?
jeremy1979 is offline   Reply With Quote
Old 10-26-2012, 03:22 PM   #2
if more information is needed, tell me where to look and i can post it. fuse panel is in a poorly lit area and need to light it up better to get a picture. will post it when i can
Old 10-26-2012, 03:58 PM   #3
Electrician
Pictures of the panels would be helpful.
dawizman is offline   Reply With Quote
The Following User Says Thank You to dawizman For This Useful Post:
jeremy1979 (10-26-2012)
Old 10-26-2012, 07:56 PM   #4
here is a picture of the panel i need 220 hooked up too
220 range/dryer outlet???-img_00000013.jpg
Old 10-26-2012, 08:37 PM   #5
2 reason why i ask.
1. can it be done so i dont waste an electricians time coming here
2 if so what will i need
Old 10-27-2012, 10:16 AM   #6
no one has any helpful information???
Old 10-27-2012, 10:32 AM   #7
joed's Avatar
Rewards Points: 13,316
The switch on the right is your main disconnect.
The range would be connected into the large block with the handle on the upper left of the fuse box. If that block is not being used then you can add the stove line. Otherwise you need to add a sub panel or replace the entire panel with one that has more spaces.
The Following User Says Thank You to joed For This Useful Post:
jeremy1979 (10-28-2012)
Old 10-27-2012, 09:18 PM   #8
as far as i can tell there is nothing hooked to it. there is nothing in the whole building that runs 220. the fuses in the upper left are 35 amp. do i need to upgrade them?
Old 10-27-2012, 09:51 PM   #9
Missouri Bound's Avatar
Jeremy...you need to relax a bit. Believe it or not we are not all here just waiting for you to ask a question. The pull out on the upper left side is what you will use for 240. Are there fuses in it now? If you pull it out, what happens, if anything. Just because the building doesn't have any 240 being used doesn't mean that that pullout isn't being used for 2, 120v circuits. Do you have the ability to figure this out? Judging by your demeanor and your questions you need an electrician. Are you qualified to open that panel and see what is wired and not wired? Get a professional to help you. And lose the attitude when you come back here.
Do you want it your way or the right way?
Old 10-27-2012, 09:52 PM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That would depend on what the range requires. Some built in ranges are as low as 20A, but typical free standing ranges will require 40A circuits.
Old 10-28-2012, 11:11 AM   #11
first of all i would like to thank everyone for the information you have given me. second.....i have not had any attitude here. Missouri, you have far more attitude here than I. do you need help reading??? my previous post states that there are 35 amp fuses in there right now. do you have the ability to open your mouth and treat people with decency and respect? i certainly have my doubts that you are qualified to do that.
k_buz it will be the typical free standing range. what i am really trying to do is have a 220 outlet put in and then use it for both stove and dryer. i realize that most dryer's and stove have slightly different plug. what i would like to know is, can i rewire the dryer or range to have the same plug to match the outlet? or would i HAVE to put in 2 outlets? would i put one in the existing space and then run a sub-panel as well?
my preference would be to only have the one outlet and have the tenent switch back and forth to what he is using.
Thanks!
Old 10-28-2012, 11:21 AM   #12
are you an electrician joed?
Old 10-28-2012, 11:27 AM   #13
k_buz's Avatar
You have to install the proper receptacle and circuit for each appliance.
However, the CEC is different than the NEC, so I don't know the exact restrictions for your situation.
Old 10-28-2012, 11:38 AM   #14
thank you. i would really like to get in contact with joed who commented on this thread. only lives 10 minutes away from me
Old 10-28-2012, 11:40 AM   #15
Rewards Points: 1,666
Jeremy,
I think you do have an attitude; remember, you are asking for help, not giving it.
You wrote:"...tenent (sic) switch back and forth to what he is using"
Sounds like a rental situation; I believe you are better served by having a licensed electrician do this with a permit so if anything goes wrong, you won't be liable. Usually, in a commercial situation like a rental, an licensed electrician is required.
bob22 is online now   Reply With Quote
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 06:37 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
