220 Plugs In Living Room? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-17-2008, 08:48 AM   #16
Originally Posted by InPhase277 View Post
It is likely a 6-20, but he said it was odd. Most people have seen a 6-20.
You have never seen a crow's foot 20 A used for a window unit? I have replaced quite a few. Apparently there was a phase in the 60's and 70's where some A/Cs had 125/250 V ungrounded plugs. I don't know why, but I've seen enough 10-20s installed to know that it happened quite often.
I always end up replacing them with either a 5-20 or 6-20
Do you just use the neutral for ground when you replace the outlets?
jerryh3 is offline   Reply With Quote
Old 12-17-2008, 09:35 AM   #17
Rewards Points: 2,350
Sometimes they are grounded, just not the receptacle. But if not, and I change to a 5-20, then I use the red as ground and white as neutral. If 6-20, then white as ground.
Most are wired with 12-3, with and without a ground. I have seen maybe two that were wired with 12-2 w/g, with the ground used as the neutral.
Old 12-17-2008, 10:59 AM   #18
What if they wired with bx with a bonding strip, couldn't you use the jacket as an egc?
rgsgww is offline   Reply With Quote
Raising step down living room questions phil. Building & Construction 10 02-05-2015 11:39 PM
Living Room Restoration Angel241 Project Showcase 34 10-05-2008 10:37 AM
Smoke detector - Living room with FP and fan ><(((jan(((D> Safety 42 12-28-2007 08:59 AM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
