220 Plugs In Living Room? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2008, 04:13 PM   #1
What instructions?
Send a message via Yahoo to ProWannabe
220 plugs in living room?
My house was built in the 1960's and came complete to me with a 220 VAC plug in the living room and another in the bedroom. Its a strange looking outlet I've never seen before and I was curious if anyone might know what types of things might have once needed 220 volts. I thought about swapping one out for a welder plug so I could watch college football while I did arts and crafts, but I decided the carpet might be too flamable!
Thanks.
ProWannabe is offline   Reply With Quote
Old 12-16-2008, 04:14 PM   #2
DIYer
Window air conditioners.
Gigs is offline   Reply With Quote
Old 12-16-2008, 04:15 PM   #3
Yep, window air conditioners...You could swap them out with 20 amp receptacles. Might as well make use of it somehow.
rgsgww is offline   Reply With Quote
Old 12-16-2008, 07:44 PM   #4
Rewards Points: 266
Originally Posted by ProWannabe View Post
Its a strange looking outlet I've never seen before...
Let's see it!
junkcollector is offline   Reply With Quote
Old 12-16-2008, 08:30 PM   #5
Originally Posted by junkcollector View Post
Let's see it!
I second that....PLEASE!
Old 12-17-2008, 06:28 AM   #6
When is fishing season?
CowboyAndy's Avatar
we used to have one in our living room, not near a window so not for a/c... i thought maybe was for a special vaccum cleaner or something.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 12-17-2008, 06:40 AM   #7
There's a few more steps involved with that. He needs to make sure to replace the double pole breaker with the correct size single pole.
jerryh3 is offline   Reply With Quote
Old 12-17-2008, 06:44 AM   #8
A NEMA 6-20, maybe...
Old 12-17-2008, 07:24 AM   #9
I know. And then you have that open knockout that you would need to block.
Old 12-17-2008, 07:36 AM   #10
DIYer
Couldn't he just make it a MWBC to two halves of a duplex?
Old 12-17-2008, 07:37 AM   #11
There's probably no neutral. Can't do it.
Old 12-17-2008, 07:40 AM   #12
My guess is that he has 12/2 bx running there.
Old 12-17-2008, 07:50 AM   #13
Rewards Points: 2,350
Or, maybe... a NEMA 10-20... gasp. Could we be so lucky as to see the elusive crow's foot receptacle?
Old 12-17-2008, 08:09 AM   #14
10-20? A 3 pole A/C plug? Maybe it will be a t-slot 6-20!!!
Old 12-17-2008, 08:31 AM   #15
It is likely a 6-20, but he said it was odd. Most people have seen a 6-20.
You have never seen a crow's foot 20 A used for a window unit? I have replaced quite a few. Apparently there was a phase in the 60's and 70's where some A/Cs had 125/250 V ungrounded plugs. I don't know why, but I've seen enough 10-20s installed to know that it happened quite often.
I always end up replacing them with either a 5-20 or 6-20
Raising step down living room questions phil. Building & Construction 10 02-05-2015 11:39 PM
Living Room Restoration Angel241 Project Showcase 34 10-05-2008 10:37 AM
Smoke detector - Living room with FP and fan ><(((jan(((D> Safety 42 12-28-2007 08:59 AM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
