220 Plug W/no Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 02:31 PM   #1
220 plug w/no ground
I want to change a 220 plug but when i removed the old one there was no ground wire. I believevthis plugbwas used for a hot water heater before. Now i want to use it for an inline, tankless, hot water heater. I like to keep everything grounded.
Mobileguy is offline   Reply With Quote
Old 05-19-2012, 02:44 PM   #2
Rewards Points: 6,652
240 is two hots and a ground and/or Neutral. Without pictures, it is hard to see what you are talking about. Now of course, if the wire you have is Red, Black, White, It is fine still to use, but again need pictures and info on the new appliance you plan on installing.
Old 05-19-2012, 05:53 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
"220" does not tell us much. What is the actual voltage? 240? or 120/240?
Also, what are the amperages? Just saying "220" is only part of the equation.
Speedy Petey is online now   Reply With Quote
Old 05-19-2012, 08:00 PM   #4
Code05's Avatar
Rewards Points: 1,104
Tells me enough that OP is probably gonna kill himself doing electrical work.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Speedy Petey (05-19-2012)
Old 05-20-2012, 02:05 AM   #5
" Euro " electrician
frenchelectrican's Avatar
What size of this tankless unit you are talking about??
Yeah I can tell if the OP tell us what size of tankless eau heater.
The biggest issue that the OP may not relized that the exsting circuit may be too small if the new tankless unit is a whole house verison that pretty much done for it.
Merci,
Marc
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 02:07 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
