220 Outlet With Sub-panel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2008, 05:53 PM   #1
220 outlet with sub-panel
Hi everyone; this is my first post . what I want to do is put a 220-volt outlet in my garage for a welder. I plan on running #6 wire to the attached garage to a main lugs sub-panel so I can have a few 110-outlets for a refrigerator and a grinder and around the work bench; however I am not sure how to incorperate the 220-volt outlet into this in a way that will be acceptable to the Inspector. please helpp.s. I will have a 50 amp circuit breaker. thank-you
metalmat is offline   Reply With Quote
Old 09-14-2008, 07:41 PM   #2
Electrician
what is the amperage of the welder? 50 amps? If so just install a surface range receptacle under the new sub-panel.
chris75 is offline   Reply With Quote
Old 09-14-2008, 08:11 PM   #3
Run your 6/3 cable w/g from a 60 amp breaker in your main panel to your sub panel.
Get a ground bus kit so the neutral is not bonded to the panel enclosure.
Terminate your 2 hots, neutral and ground.
Install a 2 pole 50 amp breaker in your sub.
Feed the 240 circuit to the welder with 6/2. You can use the same 6/3 if you like. You will just have an extra white wire in it.
Feed the 120 receps with 12/2 wg, each one on a seperate circuit.
Install the proper recepticals, Turn it on test it and plug stuff in.
220/221 is offline   Reply With Quote
Old 09-14-2008, 08:22 PM   #4
Electrical Contractor
kbsparky's Avatar
Originally Posted by chris75 View Post
.... just install a surface range receptacle under the new sub-panel.
(Ahem) The proper configuration for most 50 Amp welders is a NEMA 6-50R, not a "range" receptacle.
Old 09-14-2008, 09:52 PM   #5
Electrician
Yes, your correct. Not sure what I was thinking.
Old 09-14-2008, 10:41 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
True yes ...but I would like to have a dollar for every 3 wire range receptacle I've seen used for the old reliable lincoln arc welders....
Old 09-14-2008, 10:55 PM   #7
thank you very much 220/221,Stubbie,chris75,Kbsparky,this helps me very much!!
Old 09-14-2008, 11:23 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Can you give us the manufacturer of the welder and model? We can then tell you exactly what you need for the branch circuit from the makers website.
Old 09-14-2008, 11:59 PM   #9
thanks Stubbie, it is a Lincoln 180 that draws 42 amps max. I already have the nema6-50r receptacle,I was unsure how to wire this in with the sub-panel.
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
