220 Outlet With Alum Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 01:07 PM   #1
220 outlet with alum wires
I purchased a new stove only to find the old one was hard wired with alum wiring.. i went & bought a surface mount range outlet AL/CU but the wires are confusing me i have a black a black with a red line one it and a bundle of alum how do i hook this up???
Tony11657 is offline   Reply With Quote
Old 02-26-2009, 02:15 PM   #2
Remodeling Contractor
you have a black, black with red stripe, white and uninsulated twisted wire? If so you need a 4 wire range plug, not a three wire one. (if you have a disconnect before the electrical panel.) For four wire, connect the two blacks to the copper colored terminals. (rectangular tab) The white to the nickle colored screw. (oval tab) and the twisted wire to the green screw. After attaching to the wall, turn on the breaker (2P50) and test. If it is not working, you may have a three wire setup. Without testing which wires are hot or connected in the panel I cannot tell you what to connect for sure.
Old 02-26-2009, 02:18 PM   #3
You have SE cable.
Twist the bare aluminum strands into a single wire. That is your ground/neutral. It will be evident which terminal to attach it to (the center).
The black wires are hot.
220/221 is offline   Reply With Quote
Old 02-26-2009, 02:40 PM   #4
Its actually code to keep the 3 wire.
Do what 220/221 said.
rgsgww is offline   Reply With Quote
Old 02-26-2009, 09:46 PM   #5
Thanks guys works great my wife is happy until she finds something else to rip up
Old 02-27-2009, 11:04 AM   #6
Rewards Points: 58
Only if it's SE cable. NM would be a violation. Actually, I do not think a three wire circuit was ever compliant, as the ground cannot be a CCC. 120/240 volt circuits require a neutral and a EGC. 4 wires.
Old 02-27-2009, 11:14 AM   #7
Rewards Points: 58
Old 02-27-2009, 11:21 AM   #8
Licensed Pro
Up until 1996, SE was compliant as were three insulated conductors, as long as the circuit originated at the main service. The wiring was considered H-H-N with the ground being permitted to be bonded to the neutral at the appliance.
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 09:17 PM
Help Help richie02 Electrical 7 06-17-2008 09:42 AM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 03:55 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
