Old 05-06-2011, 02:03 AM   #1
220 outlet
Im installing a 3-prong outlet for a dryer. I understand the black and red are the hot wires and the green/copper is the ground. Do I just cap off the white wire on both ends?
Mikeystone is offline   Reply With Quote
Old 05-06-2011, 02:38 AM   #2
220 outlet
NO! 3-prong cords must have the ground and neutral connected together inside the dryer. Normally, there's a metal strap that goes from the center neutral terminal to the chassis of the dryer.
Can you snap a pic of the inside of the dryer for us, and post it here?
Old 05-06-2011, 02:44 AM   #3
220 outlet
Here's a pic of how the inside of the dryer is wired.
Old 05-06-2011, 04:32 AM   #4
Scared Electrician
Saturday Cowboy's Avatar
220 outlet
You SHOULD install a 4 wire outlet and retrofit the dryer cord(easy). A 3 wire system(which is no longer legal to install for good reason) Has the neutral(white) connected to the plug and the ground is not used and CANNOT connect to the receptical(tho if metal box must connect to box.)
A three wire system used the neutral as a ground(or is it ground for a neutral). It is grandfathered in for previous installs, but should be upgraded if practical to a 4 wire system in which you have 2 hots a neutral and a ground.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-06-2011, 06:59 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
220 outlet
Where are you installing this receptacle and why???
A new dryer circuit/receptacle install REQUIRES a 4-wire receptacle with a neutral AND a ground.
Even if you had a 3-wire there before I would change it.
Old 05-06-2011, 08:56 AM   #6
220 outlet
What Cowboy and Speedy said!
I was under the impression that he had an existing 3-wire receptacle, and a 3-wire cord (not sure if one has to change the receptacle if it's already there).
But you should change the receptacle, yes, if at all practical.
Switched Outlet Issue mjm Electrical 11 01-23-2011 08:41 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
