220 Neutral Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 08:49 AM   #1
220 neutral problem
I have 240 volts from red to black, nothing from eirther one to neutral,,what should i look for to fix?
BrendonJHardy is offline   Reply With Quote
Old 03-13-2012, 08:58 AM   #2
Rewards Points: 2,516
You think maybe a little more information may be needed?
At what location is this occurring? At an appliance? At the load center?
hammerlane is offline   Reply With Quote
Old 03-13-2012, 09:32 AM   #3
Licensed Pro
Make sure the neutral is connected at the other end.
Old 03-13-2012, 10:49 AM   #4
Rewards Points: 204
Are you sure you need the neutral? 240 circuits are not all created the same. But like HouseHelper said. Check the other end.
strange electric problem in new house, hot ground! area123 Electrical 29 07-25-2010 11:29 AM
MWBC bad neutral test results! kbsparky Electrical 15 04-06-2010 08:44 AM
three way switch problem Scavanger Electrical 33 02-09-2009 02:44 PM
Problem with Neutral Connection kbrigham Electrical 4 03-11-2008 07:00 PM
Can I add a second grounding bar to a GE box? Rodsnreels Electrical 40 02-21-2008 10:58 PM
