220 Motor To 208 3 Phase - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2008, 09:36 PM   #1
Question
220 motor to 208 3 phase
Hello this is my first post .My business is in a commercial area so power in the building is 120/208 3 phase i have been given a radial arm saw that only runs on 220 single phase. I have been told i can run this saw but no one seems to be able to tell me how to wire outlet for this.Can someone please help me.Thank you in advance for your time.
Cacman1 is offline   Reply With Quote
Old 09-21-2008, 09:39 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
simply put:
2 of the hot legs of the 3 available in the panel. That will provide you with 208 single phase but if the motor data tag actually lists 220 volts, you should have no problems witht the 208 volts.
Old 09-22-2008, 05:49 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Even more simply put. This is a commercial setting. You should NOT be touching the electrical there. Hire an electrician.
1 phase generator feeding a 2 phase transfer switch MAP40 Electrical 12 01-01-2009 07:38 AM
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
3 Phase Converter Wiring ideffects Electrical 22 05-26-2008 08:05 PM
3 phase electricity J187 Electrical 11 10-26-2006 01:40 PM
