220 Fuses - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 04:16 AM   #1
220 fuses
My dryer is not heating and was told to change the fuse. I cannot find the 220 volt fuse in the basement. Where would this be located?
Dreams1111 is offline   Reply With Quote
Old 07-14-2012, 04:19 AM   #2
220 volt fuses
[quote=Dreams1111;965302]My dryer is not heating and was told to change the fuse. I cannot find the 220 volt fuse in the basement. Where would this be located? What is the difference between a 220 volt fuse and a Main house fuse?
Old 07-14-2012, 05:24 AM   #3
Rewards Points: 1,548
There would be two 120 volt fuses (or breakers) instead of one 240 volt.
They should be but are not guaranteed to be next to each other or, in the case of breakers, in the same double wide unit.
You should measure 240 volts between the terminal screws for the respective fuses/breakers or 120 volts from each of the screws to neutral.
The Following User Says Thank You to AllanJ For This Useful Post:
Dreams1111 (07-14-2012)
Old 07-14-2012, 07:44 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Do you even know that you don't have power to the dryer?
Old 07-14-2012, 07:56 AM   #5
Yes everything seems fine on the dryer. I checked the heating element, the fuse on the dryer and both thermostats and all were ok. The dryer works, but will not heat.
Old 07-14-2012, 08:02 AM   #6
You did not do any electrical work recently or in the meantime at the time the dryer stopped heating, did you? (re-arranging the circuits so the "240 volts" supplied to the dryer becomes zero volts even though you still measure 120 volts hot too neutral).
It is not unusual for the heating element in the dryer itself to fail.
Old 07-14-2012, 08:10 AM   #7
biggles's Avatar
with no power connected close the stats and ring the elements out with OHMS should show resistance or a dead short if good infinity the element is "broken" as in open if you have continuity then maybe the HI-LIMIT cap tube wore out and lost its charge if it has one...silver disc like obhject with 2 wires coming from it
Old 07-14-2012, 08:12 AM   #8
MarginallyQualified
Rewards Points: 2,464
Do you have power AT the heating element?
Which of the dryer heat controls do you have power to/through?
Old 07-14-2012, 08:20 AM   #9
Yes there is power to the dryer and everything was checked and working. No new electrical work of any kind has been done.
Old 07-14-2012, 08:36 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Everything but the heat, right? Is there 240V to the dryer???
WHO told you to "change the fuse"?
Old 07-14-2012, 09:30 AM   #11
There is 220 volt to the dryer and it is also working. Yes everything works except the heat. The people at the appliance parts store said to check the house fuses. I did that this morning and they are also good.
Old 07-14-2012, 09:36 AM   #12
So then the problem is obviously the dryer, and not the circuit.
Old 07-14-2012, 09:48 AM   #13
MarginallyQualified
Can you measure 240V at the heating element connectors?
If not... then work your way through the control circuit to see where the power is being stopped. It can be tedious but it isn't rocket science.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Heat pump wiring and fuses icandoitmyself1 HVAC 13 06-01-2014 04:15 AM
Air conditioner keeps popping fuses BrandenG Electrical 6 06-20-2012 04:19 PM
Replacing 240V fuses for dryer Mark77 Electrical 14 01-10-2012 09:06 PM
Goodman central air and heat blowing fuses DannyR HVAC 13 05-29-2011 06:21 PM
Intertherm elec furnace slowly burns 60A fuses. Goldenvoice HVAC 9 01-05-2011 10:29 AM
