220 Feet To Tool Shed. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 09:53 AM   #1
220 feet to tool shed.
I know very little about electricity. I recently built a 12x24 man cave shop with 3 16x24 covered bays attached for my tractor, boat and trailer (happy man). I am researching how to wire it properly. I have 200 amp service to the main house. There are 2 empty breaker slots in the inside panel. I was told I could put 1 60 amp breaker or 2 30's (double pole 30's?) in there. I was told 6-3 or tray wire without conduit underground, could carry the juice to my shop 200 feet away. I want to run a fish, beer, and ice fridge continually, a couple of FL shop lights in the evening, and and occasional small power tool/battery charger. I plan on putting a box in the shop to split the power through 2 30 amp breakers. Does this seem OK so far. Any help would be appreciated.
Joe Willie is offline   Reply With Quote
Old 12-13-2010, 10:20 AM   #2
Rewards Points: 256
There are many books designed for beginners covering how to add a sub-panel. Get yourself one, teaching every aspect over a forum is too much.
You will need to use wire rated for underground use.
michaelcherr is offline   Reply With Quote
Old 12-13-2010, 10:43 AM   #3
Licensed electrician
Rewards Points: 1,630
One thing that is incorrect in your plan is the use of the 30 amp breakers at the shed. General use circuits are prohibited from being greater than 20 amps.
You can check the stickies on this forum for subpanel installation information.
Old 12-13-2010, 12:07 PM   #4
distance vs power loss per wire size formula
I guess my main question is... will 6-3 or smaller carry the juice 200 ft without much loss in power?
Old 12-13-2010, 12:29 PM   #5
Using #6 wire (depending upon exact wire) will give you 40a 240v with a 3.2% voltage drop
Are you sure the wire length will be 200'
Or longer with going underground then up to the panel at either end ?
Do I have any more electrical service capacity? (Power for Shed) Magnus357 Electrical 7 10-13-2012 08:52 AM
Shed questions Piedmont Electrical 12 10-20-2009 09:06 PM
shed roof over old deck bluegrass General DIY Discussions 3 09-12-2009 01:03 PM
shed power suggestions rsriverrat Electrical 36 12-29-2008 12:42 PM
Help with wiring in shed sandyman720 Electrical 1 06-25-2008 11:11 AM
