220 Extension Cord Question.. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 08:16 AM   #1
220 extension cord question..
Hello everyone,I have a question about a forklift battery charger i bought. Ok,its an exide forklift battery charger 36 volts. It weighs a ton so i am having to run a 25 foot extension cord to it. My question is,my 220 wall outlet has three holes so i went to lowes and made a 220 extension cord. Now i get to the ac cable coming out of the charger that hooks to the extension cord(plug was cut off),there are 4 wires coming out of the cable green,white,red, and black......the guy at lowes said i could buy a 3 prong plug for it to plug into the female end of the extension cord because one of the 4 wires is probably neutral and i wouldnt have to hook up but the green,white and either the red or black.....is he right? Inside the charger the red,white and black all go to big fuses and green to ground. Also above the fuses it says "factory set to 480 volts ac". I guess my question is,will this charger only work using a 4 prong wall outlet(mine only has 3) and with 4 prong plug hooked to cable coming out of the charger itself or is the guy at lowes right in saying that only the red OR black wire has to be used? Sorry if this is confusing but ive searched and searched online for 3 days and havent found anything. Thanks in advance for any help-Kevin
kmyer74 is offline   Reply With Quote
Old 04-24-2012, 08:20 AM   #2
I=E/R
a7ecorsair's Avatar
This is your first problem
Do not plug this in to anything until you understand this charger. It could be three phase.
a7ecorsair is offline   Reply With Quote
Old 04-24-2012, 08:24 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,938
Three fuses and a 480V rating? That's a 3-phase charger. Unless it can be rewired for single phase, you can't use it on a single-phase supply. What is the model number?
mpoulton is offline   Reply With Quote
Old 04-24-2012, 09:56 AM   #4
Its a D3-18-850B
Old 04-24-2012, 10:59 AM   #5
Rewards Points: 3,256
Originally Posted by kmyer74 View Post
Its a D3-18-850B
I'm only finding that model in 3-phase. Perhaps you could contact Exide
and see if they offered this model in single phase.
zappa is offline   Reply With Quote
Old 04-24-2012, 01:40 PM   #6
charger
hi we have 15 chargers here all but one are 3ph, your have to get 1ph charger and should be a 50amp plug . make sure you have enough power .
shockme123 is offline   Reply With Quote
Old 04-24-2012, 02:46 PM   #7
I=E/R
a7ecorsair's Avatar
Aside from getting it to work....
What do you plan to do with this charger?
How many wires in Romex v. extension cord? Leah Frances Electrical 31 06-02-2010 10:24 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 09:11 PM
Pull cord light question 737Pilot Electrical 5 12-21-2008 09:49 AM
Multi ended extension cord Rze Electrical 6 09-22-2008 10:17 PM
Ganged Extension Cord Rze Electrical 15 08-04-2008 05:27 AM
