220? Electrical Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2007, 11:52 AM   #1
220? Electrical question
We have a old house that has 220? and 110? power lines going to it(not usre about this)
one is about straight from the power line to the wallbox and the other is like it comes from nowhere to a shut off box(220?)
how can we shut off the (220?) from the pole?(if possible)
coondog7 is offline   Reply With Quote
Old 11-16-2007, 12:18 PM   #2
Rewards Points: 1,910
You'll have to call an electrician.
Old 11-16-2007, 12:36 PM   #3
It doesn't sound like you've got much of an idea of what's going on there, and from your description I'm not sure anyone here will be able to figure it out either. My guess is that you're misunderstanding which wires coming to your house are power lines.
Nearly all houses in the US (are you in the US) are fed with 220V power on two hot wires. They enter the house through a service panel. From that panel, circuits can be fed with one hot wire for 110V applications, and two hot wires for 220V applications.
So, what is it that you are actually trying to accomplish? Why are you trying to shut off all 220V power in your house? Explain the begining of your problem, and people here may be able to tell you how to solve it, or what to ask an electrician to do for you.
NateHanson is offline   Reply With Quote
Old 11-16-2007, 12:55 PM   #4
waiting for spring
arichard21's Avatar
Rewards Points: 150
coondog,
cable and telephone also usually come from the same pole, or nearby.
my in laws house has underground powerlines, but the phone and cable come from the pole.
could be the same in your situation, or vice versa.
arichard21 is offline   Reply With Quote
Old 11-16-2007, 04:40 PM   #5
Rewards Points: 410
Yeah, my guess is the same as arichard21. Sounds like the power is coming in burried, the phone & cable are coming in off the pole and coondog is thinking both are power. I used to as well.
Piedmont is offline   Reply With Quote
Old 11-16-2007, 08:55 PM   #6
Electrician philosopher
I wonder why he wants to kill it....huh.
Andy in ATL is offline   Reply With Quote
Old 11-19-2007, 10:04 AM   #7
Which is why I thought he should call an electrician.
Home Electrical / Car Stereo Question pjpjpjpj Electrical 4 08-12-2012 07:59 PM
Electrical Question BlueShoe2005 Electrical 1 09-10-2007 05:12 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
