220 Dryer Plug Connecting To Tanning Bed - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 10:27 AM   #1
220 dryer plug connecting to tanning bed
Can you plug a tanning bed (230v 17 amp) to a 4 prong dryer plug
Tbtburg1963 is offline   Reply With Quote
Old 11-06-2011, 11:59 AM   #2
You should install the proper outlet, wiring, and circuit breaker that the manufacturer recommends.
That way if there is a malfunction with the bed, the breaker will trip when it should.
What amperage circuit do they recommend in the instructions? What kind of plug does it have?
Billy_Bob is offline   Reply With Quote
The Following User Says Thank You to Billy_Bob For This Useful Post:
Code05 (11-06-2011)
Old 11-06-2011, 04:04 PM   #3
Rewards Points: 1,216
Post a picture of the plug on here and the nameplate data.
COLDIRON is offline   Reply With Quote
Old 11-06-2011, 05:12 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
I would make sure the receptacle you use has GFCI protection unless the tanning bed has integrated protection.
Coastal South Carolina
Old 11-06-2011, 06:15 PM   #5
Licensed electrician
Rewards Points: 1,630
Is the tanning bed 120/240 or 240 only?
The bulb life will be shortened if the voltage is listed for 230 according to some bed manufacturers.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Help converting dryer plug to welder plug. RodBarney Electrical 18 07-22-2011 07:18 PM
Installing a 4 prong dryer plug Amandamayes Appliances 4 07-16-2010 01:17 PM
Can you change a 220v plug on a dryer clueless_03 Electrical 6 08-30-2009 01:39 AM
Running new dryer wire...but dryer is three plug currently. RyanD Electrical 7 08-07-2009 02:33 PM
