220 Barn Sub Panel Help - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2014, 05:10 PM   #1
220 barn sub panel help
Hi all,
I've have a sub panel in my barn that is used to run my pool. It is 220v at the sub panel but has a breaker that's only using one of the legs for a 110v outlet.
The 110v outlet is not grounded and I would like it to be since it's running pool equipment. I'd like to keep the sub panel providing a single 110v outlet but update it to be grounded. Any feedback would be appreciated! I'll post pics shortly (4 more posts)
Thanks!
jimmertimmer is offline   Reply With Quote
Old 06-18-2014, 05:11 PM   #2
The line in is two hot, one neutral, and a ground.
Old 06-18-2014, 05:11 PM   #3
2 more until pictures
Old 06-18-2014, 05:13 PM   #4
1 more
Old 06-18-2014, 05:17 PM   #5
Last post before pictures.
Old 06-18-2014, 05:23 PM   #6
Still unable to post pictures. Hopefully this post will break the threshold.
Old 06-18-2014, 05:23 PM   #7
Here are the pics:
Old 06-18-2014, 05:48 PM   #8
Rob
Robpo's Avatar
Rewards Points: 826
I hope this helps
Robpo is offline   Reply With Quote
Old 06-18-2014, 06:24 PM   #9
Rewards Points: 1,832
Id replace the panel. Anyway, its not wired right. Neutral and ground are on the same buss.
Jump-start is offline   Reply With Quote
Old 06-18-2014, 07:48 PM   #10
Rob
Robpo's Avatar
Rewards Points: 826
I don't see a ground wire to outlet unless that is metal conduit, BX wire or what ever it is called nowadays( metal cable) so you might have to replace the wire or put in a ground depending on the situation.
power new 200amp panel as temporary subpanel from existing 100amp main panel CapeCod153 Electrical 4 03-21-2013 09:31 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
another barn wiring question wendell2 Electrical 10 05-29-2011 09:04 PM
Critique my Sub Panel rjniles Electrical 18 05-18-2011 12:31 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
