220 60 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 06:15 AM   #1
RSC
220 60 amp breaker
Can I hook-up a Dryer and hot water heater on the same circuit?
RSC is offline   Reply With Quote
Old 09-23-2010, 06:28 AM   #2
No, should be seperate circuits. WH is usually 20A, Dryer could be more, but if you put both on a 60A and one has a short/problem, the breaker will not trip until the house burns down.
The Following User Says Thank You to Just Bill For This Useful Post:
RSC (09-23-2010)
Old 09-23-2010, 11:54 AM   #3
RSC
Hey Bill,
Would it be possible to lower the breaker? It's 6/2 wire coming from the panel, I was going to splice in 10/2 for the HW in a junction box and continue the 6/2 into the dryer plug.
Old 09-23-2010, 12:06 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by RSC View Post
Hey Bill,
there are a lot of special rules for taps. For residential purposes, I will not get into them. You should simply run the proper wire and have dedicated circuits for the 2 appliances.
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 09:57 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 10:13 PM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 08:20 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
