220/380 3 Phase 5 Hp Wiring Digram - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 05:59 PM   #1
220/380 3 phase 5 hp wiring digram
I have a new motor from China and i do not know how to wire to the power source to 220 3 phase electrical outlet.
the motor has 4 wires that hook up. the cord has green which is ground, and a red white and black wire.
On the machine there is three hookups. the top says W2, the second says U2, and the third says V2, and the green is to ground on the motor.
John Carcich is offline   Reply With Quote
Old 09-08-2012, 06:41 PM   #2
Rewards Points: 13,740
And do you have 3 PH incoming power even avalible?
Old 09-08-2012, 11:22 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Do this motour you have there did came with nameplate on them ??
Is this actual three phase or single phase motour due there are some single phase motour use 4 conductor hook up.
But If your place actually have three phase source then this part you will need to verify the link or connection to proper voltage as the nameplate posted there.
Or take a photo one of us will able indentify it.
And there is something missing there you should have W1 , U1 , V1 as well where it is ?
Merci,
Marc
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Converting single phase to three phase ogoa Electrical 13 02-05-2012 09:36 PM
Three phase transformer question rongaudier Electrical 8 03-08-2011 07:19 AM
3 phase electricity J187 Electrical 11 10-26-2006 01:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
