220 To 240 How To - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 07:28 PM   #1
220 to 240 how to
I need to turn a 220 outlet in to a 240 outlet for my air compressor
brandon.cowley is offline   Reply With Quote
Old 04-16-2012, 07:48 PM   #2
Master Electrician
Rewards Points: 3,678
220 is 240.
brric is online now   Reply With Quote
Old 04-16-2012, 07:52 PM   #3
Rewards Points: 776
?!?!?!??? What is it you have today? Dryer, Oven, Other?
220V vs 240V isn't the difference. You either have 120V or 240V circuits in residential. They are either phase to neutral (120V) or phase to phase (240V, no neutral).
How many amp branch circuit is required for the compressor (@ 240V)?
curiousB is offline   Reply With Quote
Old 04-16-2012, 08:38 PM   #4
Rewards Points: 1,418
Check the wiring going to that receptacle. Twelve gauge supports at most 20 amps,ten gauge supports at most 30 amps, eight gauge supports at most 40 amps.
Provided you stay within the wire amperage limits, you can swap out the receptacle for one that matches the plug for the compressor which in turn should match the ampere requirement of the compressor. (Receptacles have ampere ratings also) Change the breaker pair unit in the panel to match.
Old 04-16-2012, 09:17 PM   #5
I=E/R
a7ecorsair's Avatar
What do you have right now for a receptacle and what do you need to match the compressor?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
a_lost_shadow (04-16-2012)
Old 04-16-2012, 09:41 PM   #6
Rewards Points: 6,652
Call your electric company and tell them in your best Captain Kirk voice, that you need more power. Then post back and tell us their reply.
