220 To 110 - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 09:15 AM   #1
Question
220 to 110
1st time and hoping someone out there can help.....
I have a 220 dryer plug in my garage. We have since upgraded to gas dryer and 220 plug is not in use. I would like to get a 3000 watt step down converter but all the ones I can find online do not have the 220 dryer plug prong set-up. What can I do?
uvsc31 is offline   Reply With Quote
Old 10-06-2009, 09:24 AM   #2
Licensed Pro
Why would you want a converter? It should be just a matter of moving wires in the panel where the circuit originates and replacing the 240V receptacle with a 120V one.
How many wires feed this receptacle and what color are they?
Old 10-06-2009, 11:04 AM   #3
Rewards Points: 126
All you have to do is get a new 125 volt receptacle with plate and a 20 amp single pole breaker. The 120 volts is already there.
If it worked before you worked on it. You did something wrong.
Old 10-06-2009, 11:46 AM   #4
Question
Can't see any of the wires. It's completely shielded. Was looking for a converter as a quick and easy fix rather than rewiring the 220
Old 10-06-2009, 03:30 PM   #5
WaldenL's Avatar
Rewards Points: 268
It will likely be quicker, easier, and cheaper, to just put in a 120V plug w/the appropriate wiring changes.
WaldenL is offline   Reply With Quote
Old 10-06-2009, 04:53 PM   #6
Household Handyman
Rewards Points: 1,408
uvsc31--It's not a complete re-wire, as stated it's only moving one wire within the breaker panel, and changing the receptacle from the 220 V, to a 110 V duplex receptacle. IMO-for less than $10 and some time, you can have a 110 V duplex receptacle there and save the monies for the converter. My two cents worth, David
Old 10-06-2009, 07:14 PM   #7
For the price of some kind of converter you can easily get an electrician to do a simple wire/breaker/receptacle change in less than an hour.
1. He will change the 2 pole (240V) 30 amp breaker to a single pole (120V) 20.
2. He will move the white wire from the old breaker to the neutral bus along with the other whites.
3. He will install a 120V receptacle (or two) in place of the dryer recep.
Turn off power and remove cover plate and receptacle. The wiring is in a box, recessed in the wall.
220/221 is offline   Reply With Quote
Old 10-07-2009, 02:08 AM   #8
Talking
Thanks you guys have been a great help!
