220 To 110? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2008, 01:39 PM   #1
Question
220 to 110?
I'm replacing my electric cooktop with a gas one. The old electric unit has 220 running to it. Can I change the breaker and send 110 through the same wire? Or must I run a new line of 12-2 or 14-2 from the box to an outlet under my countertop?
It is tempting to see if I can just cannabalize the wire that is aready there for my new appliance rather than start from scratch. Thoughts?
mathewmarie is offline   Reply With Quote
Old 11-08-2008, 01:47 PM   #2
Rewards Points: 2,350
Sure. You need to change the breaker to a single pole 20 A. Since you likely have a 3-wire cable there, one wire goes on the new breaker, one wire to the neutral bar, and the last wire to the ground bar. Most cooktops I have wired had a 10-3 going to them. So, hopefully you already have a ground and white wire. All you need to do is use one of the hots.
Old 11-08-2008, 02:07 PM   #3
thanks
Old 11-08-2008, 03:23 PM   #4
Electrician
Rewards Points: 794
If it is old wireing you may only have two hots and a neutral with no ground. If this is the case I would get some green tape or green heat shirnk and make one of the hots your ground. Make sure you change the colour in the panel as well. Not sure what code says about doing this but if I am out in left field with this idea someone will be here to tell me so.
darren is offline   Reply With Quote
Old 11-08-2008, 05:11 PM   #5
Smile
I appreciate the tips and advice.
When I looked inside the box where my old wiring is, there is a ton of electrical tape. Since I won't start the project for a few days, I won't know exactly what I've got in there until then.
I'm sure it'll be a breeze. I just feel tense about the 220 thing. I've never been near 220. Lots of 110, lights, switches, outlets, etc., but 220 is pretty unforgiving stuff.
I feel pretty good about the project. Thanks for all your help.
Old 11-08-2008, 06:35 PM   #6
It isnt too hard. But when you switch the double pole out, the second space must be blocked. Cap the red wire. *edit: Do not reidentify the ground conductor*
rgsgww is offline   Reply With Quote
Old 11-08-2008, 07:57 PM   #7
if you dont have a ground, put some green tape around the red
I can't stand code violations, even if their "little".
Isn't it a "little" code violation to reidentify wire in this case?
I'm not saying dont do it. I'm just sayin............
240V = two hots.
120V = 1 hot, one neutral.
If you have a two wire cable (plus ground), reidentify one of the hots as neutral (white) and move it to the neutral bus (technical code violation).
If you have a three wire cable (plus ground) just cap off one of the "hots".
220/221 is offline   Reply With Quote
Old 11-08-2008, 09:49 PM   #8
Always learning...I just read article 200.
