09-09-2008, 01:38 PM
#1
220 to 110?
hi i was wandering if theres a way to wire up a 220 electric motor to 110 (regular household plug) ?
thanks
09-09-2008, 02:04 PM
#2
Licensed electrician
220 to 110?
If you could post the nameplate data from the motor it would help greatly. Some motors can be changed, others cannot be.
09-09-2008, 02:45 PM
#3
220 to 110?
What jim port said is probably your best bet.
Its possible, I think if it was hot to neutral (120) instead of l1-l2 (220-240) it would pull alot more amps, so don't expect to run it on just any household circuit.
Otherwise its always easy to pull 10/3, sometimes 8/3...not so sure about 6/3
If it comes down to pulling wire...id be glad to help you.
09-09-2008, 03:49 PM
#4
Licensed Electrical Cont.
220 to 110?
What if it is a 1/2 or 1/4 HP motor??? Still think you need 8/3???
Also, why X/3 wire? You think a motor is going to need 120/240v? I've never seen one that did.
09-09-2008, 04:36 PM
#5
220 to 110?
Well it depends on the size of the motor.
And yes you don't need x/3 wire for that, just giving an example.
09-09-2008, 05:15 PM
#6
220 to 110?
ok heres the inside on it..it is a motor for a fan what people call "squirel cages" and heres what the plate said..
Magnetek Universal Motor
V-208/230
HZ 6 Amps 3.2
RPM 1075
SP PH1 CAP 7.5MFD 370 VAC
it has a white,black,red,and blue wires coming out of it and then going into a coil pack looking thing then to what would be a plug or even i guess hard wiring..right now theres nothing on it..i would like to get it to where i can put it where ever in my garage like a normal fan...thanks again let me know if theres anything else and please bare with me in still new at the wiring part....
09-09-2008, 06:06 PM
#7
220 to 110?
Exactly my point, we don't know the size of the motor. So WHY suggest 10/3, 8/3 or even 6/3???
#8
220 to 110?
V-208/230
HZ 6 Amps 3.2
RPM 1075
This is a 208-230 volt motor. It CANNOT be wired for 120v.
09-09-2008, 06:08 PM
#9
220 to 110?
Then, no.
If it said 120/240 you could wire it either way.
If it says 220/221, send it back.
09-09-2008, 06:34 PM
#10
220 to 110?
well that sucks a little bit...well then i guess ill try to find a way to use it as it is or a replacement motor maybe..again thanks everyone for all the help and info...
09-09-2008, 09:31 PM
#11
220 to 110?
You could wire in a separate 220 circuit for the motor.
09-09-2008, 10:29 PM
#12
220 to 110?
Hold on...you could run a 240 v line. Maybe you could post pics of the location and the panel.
Whats the total distance from the panel to the site?
Looks easy...a distance of 30+ft you could use 10/2...remember no neutral required. But due to the cost of copper...it might be wise to use 10/3 in case you need 120/240 in the future.
09-09-2008, 10:35 PM
#13
Electrician
220 to 110?
The motor draws 3.2 amps, what are you guys smoking?
09-09-2008, 10:42 PM
#14
220 to 110?
marijuana to be exact.
Actually I did not see that...looks like 14/2 should work.
Is this hardwire?
09-10-2008, 01:19 PM
#15
220 to 110?
ill try to get an idea as of where i want it and get some pictures to.i was kinda hoping to get it to where i can move it around but cant always get what u want....thanks
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
