22 Awg Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 12:11 PM   #1
22 awg wire
can I use 22awg wire for the garage door button?
jgrenier is offline   Reply With Quote
Old 04-23-2013, 12:16 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
Should be fine.
I prefer something bigger.
jbfan is online now   Reply With Quote
Old 04-23-2013, 12:42 PM   #3
Ok, like what? Lowes suggested 18 . but, I have 22 and just need a second button in the garage area.
Thanks for your help by the way!
Old 04-23-2013, 12:43 PM   #4
jbfan's Avatar
Rewards Points: 246
How far is the run/
I would use 18 also.
Old 04-23-2013, 12:56 PM   #5
Not very far. it's a 16 foot garage opening and I simply need to move the button to the inside of the garage. So half way over about 8 feet and down about 4 feet. 12 feet? Just trying to keep a tenant out...
Old 04-23-2013, 01:45 PM   #6
Rewards Points: 83
I don't see a problem with using the #22 wire. It is very low current and very short duration.
Look here:
http://www.stardoorparts.com/Wire-fo...s-p/35265b.htm
davido30093 is offline   Reply With Quote
Old 04-23-2013, 01:49 PM   #7
If you have it, use it. Low voltage, low current, momentary usage, no issues. If it doesn't work, then you will know because the opener won't respond and you can get something heavier.
FixitDragon is offline   Reply With Quote
Old 04-23-2013, 01:52 PM   #8
Thank you all.. Just wanted to be sure before I started. Enjoy your day!
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 03:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
