22/4 Or 18/4 Alarm Control Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 08:11 AM   #1
Rewards Points: 150
22/4 or 18/4 alarm control wire?
I'm installing a control panel in my garage with a run in conduit I recently buried. The distance between the main panel and garage controller is about 100'.
What size control wire do I need - 22/4 or 18/4?
sheslostcontrol is offline   Reply With Quote
Old 10-27-2010, 08:35 AM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,864
#18 2 pair is always used for Alarm & Thermostat wiring.
Old 10-27-2010, 08:46 AM   #3
Rewards Points: 150
Good, but this is for the key pad / control panel, which requires 4 wires. I've seen many use 22/4, but the guy at home depot (who said he did not work with alarm systems for a living) said I might use 18/4 instead.
Tags
alarm , alarm wiring , security
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 10:41 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
